Geloppy gearbox
Sean Trollope
Car Make: VW. Hyundai.
Car Model: Citi golf. Hyundai i10
Geloppy gearbox
Post by Sean Trollope »
So after many frustrating hours spent fiddling with the linkages. Replacing bushes. Changing oil. Trying additives. I have come to the realization that there is something wrong inside the gearbox itself. All the gears work normally. But 5th will quite often and annoyingly slip out when cruising along. Making me look like a total cake. It goes into all the gears with no trouble so the synchro is fine. What else. What must I do or try to fix it. I'm incredibly frustrated.
*this is on my 1997 Chico 1.3 with 220000km on the clock. I believe the gearbox is still the original. If I'm correct it is an ffz. I'm no stranger to hard work and am not scared to pull the box out and work on it.
Sean Trollope
Re: Geloppy gearbox
Sorry I posted in the wrong place. Was a mistake
dcmk4
Registered for: 10 years
Car Model: MK7 GTi
Re: Geloppy gearbox
Post by dcmk4 »
Do you ever have issues going into 5th or is it just slipping out of gear while driving erratically?
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
Sean Trollope
Re: Geloppy gearbox
No No issues going in. And yes it does just randomly slip out
Sean Trollope
Re: Geloppy gearbox
I also did replace the dedent plunger as it was totally shot but it hasn't helped.
Rudi46
Registered for: 14 years 6 months
Car Make: Nike
Car Model: Walk and see more
Re: Geloppy gearbox
Post by Rudi46 »
5th gear sits in die last piece of gearbox. Can be fix with gearbox in car. Sounds like those dogs or whatever you cal it that flips when you select gear is worn. Should be a easy fix if you google enough
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Sean Trollope
Re: Geloppy gearbox
Thanks. Will look into it
Re: Geloppy gearbox
Or it simply needs adjustment. There is an adjustment on the end of the fork on the rod. It's possibly not engaging properly.
Sean Trollope
Re: Geloppy gearbox
Thinks. Is all of this accessible via the cover on the end of the box that has vw on it
Howie-WP
Membership No: 2033
Re: Geloppy gearbox
Post by Howie-WP »
"Geloppy gearbox" ...... :crazy: :crazy:
buggyfan
Registered for: 13 years
Car Make: mk1
Car Model: GTX
Re: Geloppy gearbox
Post by buggyfan »
Have a look here....... Www.brokevw.com
Sean Trollope
Re: Geloppy gearbox
Well I took the cover off and the long pin with a spring at the end decided to come with. So yeah. Turns out I need to strip the box to get it back.
Sean Trollope
Re: Geloppy gearbox
Turns out it's a Dgg box. And I have sent it so a good friend who knows his stuff. As the whole thing needs to be stripped down and all sorts of crap
PapaJo
Car Make: VW's
Re: Geloppy gearbox
Post by PapaJo »
panic-mechanic wrote: Thu Nov 15, 2018 8:47 am Or it simply needs adjustment. There is an adjustment on the end of the fork on the rod. It's possibly not engaging properly.
:iagree:
Sean Trollope
Re: Geloppy gearbox
So stripped the whole gearbox down. Did all the required adjustments. Also found that the bearing the sits where the selector shaft goes on was non existent. So had a solid one machined out of brass as nobody could supply me with one. Gears all select like a charm.
