Hi Guys
Quick question as per the header....
Will I run into any issues of the Dicktator STD unit losing it's settings if I change batteries or can I change it out without any issues of remapping etc etc
Reason being is I may need to consider having the battery changed up as I sometimes experience a slow start on the colder mornings as of recent here in PMB
Looking forward
Ahmed
Changing Car Battery while running Dicktator
- Car Model: Citi Rox 1.4i
Ahmed Syed
- Fidgeter
Re: Changing Car Battery while running Dicktator
You won't have any issues changing it. The map is saved on the management.
2005 Citi Golf
Current mods: 2lt 8v Single throttle
Estas cam
Branch with 57mm exhaust
Estas cam
No issues at all.
Disconnect + positive terminal first and then the - negative terminal on current battery. Install new battery in reverse order, by connecting - begative terminal first and then + positive terminal. Do this with ignition switched off.
