Which oil?
- Car Model: Mk2 jetta cli 8v kjet
Which oil?
Hi
So after some spirited driving saterday,I noticed my tappets is a bit noisey. So this morning on startup it's still the same(been parked since Sat), on my short 3km drive to work there was no change.
With the service around the corner I called a couple of spare shops and got the following advise.
A: I should use Shell helix 25w-60 High milage.
B: I should use Shell helix 10w-40.
C: Recommend Shell helix 20w-50, but not for long as it will/can break the motor.
I was using Engine 20w-50 Multigrade all along, but think it's time for change.
Car in question is mk2 jetta cli 190k on the clock
I know there is a couple of discussions about this, but just need to know what you think about these advise I got and your experiences.
2016 Polo Vivo 1.4
17" Audi A7 reps
1987 Jetta 2 Cli 1.8 8v
276 cam, powerflow, 60 mm drop, 14 inch gold "mushroom"
Ex :
1985 Ford Sierra 1.6
Stock motor, 15 inch black steelies - Sold
2016 Polo Vivo 1.4
17" Audi A7 reps
Ex :
- chucker02
- Car Model: Citi ADY
Re: Which oil?
Sounds like its time for new lifters. 20w50 is the correct oil for the car
1971 VW beetle
1971 VW beetle
Re: Which oil?
Thanx for the reply Chucker02
You might be right. My thought was it might be the oil that is a bit to thin by now.
So i'd rather want to service the car and see what happens before i start replacing lifters.
2016 Polo Vivo 1.4
17" Audi A7 reps
Ex :
2016 Polo Vivo 1.4
17" Audi A7 reps
Ex :
Re: Which oil?
Please share the name of this place so that everyone else can avoid it at all costs. They clearly have no clue what they are talking about....
Re: Which oil?
There are 100's of thousands of km's done by those engines on 20w50 without any of them blowing up. I raced a similar motor on regular helix 20w50 for years. No blowing up. change the oil if you have doubts about it to fresh 20w50 but most likely jut lifters that are past their due date.
INA make lifters from goldwagen. Done.
Re: Which oil?
Ordered new oil, filter and plugs, will be changing it later this week and see what's the outcome.panic-mechanic wrote: ↑Tue Oct 16, 2018 10:33 am There are 100's of thousands of km's done by those engines on 20w50 without any of them blowing up. I raced a similar motor on regular helix 20w50 for years. No blowing up. change the oil if you have doubts about it to fresh 20w50 but most likely jut lifters that are past their due date.
I'd rather not mention the name, coz it's the first time I got such bad advise from said shop. All previous dealings was good.
Thanks Guys
2016 Polo Vivo 1.4
17" Audi A7 reps
Ex :
2016 Polo Vivo 1.4
17" Audi A7 reps
Ex :
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Re: Which oil?
*Side note* Lifters are not that expensive.
Contact Goldwagen and check pricing brand is INA.
- Neuk
- Treasurer
- Membership No: 806
Re: Which oil?
Bloody hell Stick to the grade and spec that was originally advised for your engine, I prefer Shell oils.ML-MK2 wrote: ↑Mon Oct 15, 2018 3:55 pm With the service around the corner I called a couple of spare shops and got the following advise.
- Dub rox
- Car Model: Citi sport 1.4i
Re: Which oil?
Vw uses Castrol if im not mistakenNeuk wrote:Bloody hell Stick to the grade and spec that was originally advised for your engine, I prefer Shell oils.ML-MK2 wrote: ↑Mon Oct 15, 2018 3:55 pm With the service around the corner I called a couple of spare shops and got the following advise.
Sent from my VFD 1100 using Tapatalk
- Neuk
- Treasurer
Re: Which oil?
I have no idea, only my MkVII Golf gets serviced by a VW dealership due to it's Automotion plan, I use Shell in all my cars including top ups if needed in the MkVII Golf.Dub rox wrote: ↑Thu Oct 18, 2018 8:16 amVw uses Castrol if im not mistakenNeuk wrote:Bloody hell Stick to the grade and spec that was originally advised for your engine, I prefer Shell oils.ML-MK2 wrote: ↑Mon Oct 15, 2018 3:55 pm With the service around the corner I called a couple of spare shops and got the following advise.
- Dub rox
Re: Which oil?
I guess its user dependant, opinions will differ from person to person. In the end they all do the same thingNeuk wrote:I have no idea, only my MkVII Golf gets serviced by a VW dealership due to it's Automotion plan, I use Shell in all my cars including top ups if needed in the MkVII Golf.Dub rox wrote: ↑Thu Oct 18, 2018 8:16 amVw uses Castrol if im not mistakenNeuk wrote:Bloody hell Stick to the grade and spec that was originally advised for your engine, I prefer Shell oils.ML-MK2 wrote: ↑Mon Oct 15, 2018 3:55 pm With the service around the corner I called a couple of spare shops and got the following advise.
- Neuk
- Treasurer
Re: Which oil?
Yep, I have always preferred Shell, so run it in all my cars and I haven't had a days issue in any of them.Dub rox wrote: ↑Thu Oct 18, 2018 9:01 amI guess its user dependant, opinions will differ from person to person. In the end they all do the same thingNeuk wrote:I have no idea, only my MkVII Golf gets serviced by a VW dealership due to it's Automotion plan, I use Shell in all my cars including top ups if needed in the MkVII Golf.
- ICE King
Re: Which oil?
Branch dependent , Have a buddy at one of the branches and he said they recently moved over to Engen petronas.Dub rox wrote: ↑Thu Oct 18, 2018 8:16 amVw uses Castrol if im not mistakenNeuk wrote:Bloody hell Stick to the grade and spec that was originally advised for your engine, I prefer Shell oils.ML-MK2 wrote: ↑Mon Oct 15, 2018 3:55 pm With the service around the corner I called a couple of spare shops and got the following advise.
Funny enough hardly any of the VW branches use's Shell , Not sure how the decision is made to decide what oil to use.
- Dub rox
Re: Which oil?
It all depends on cost nowadays... Don't know if they are put thrue stringent quality tests or just opt for wich is cheaper so they can profit more or they get better deals by buying it in bulk.ICE King wrote:Branch dependent , Have a buddy at one of the branches and he said they recently moved over to Engen petronas.Dub rox wrote: ↑Thu Oct 18, 2018 8:16 amVw uses Castrol if im not mistakenNeuk wrote:Bloody hell Stick to the grade and spec that was originally advised for your engine, I prefer Shell oils.ML-MK2 wrote: ↑Mon Oct 15, 2018 3:55 pm With the service around the corner I called a couple of spare shops and got the following advise.
