MK2 Engine Bay Wiring
- Car Model: MK2 GTi, Polo 1.9TDI, MK4 1.6
Good Day you wonderful People.
I was browsing the Forum a couple of times in looking for help with my Current Project.
I have found some very Helpful hints concerning My MK2.
My Question for you guys is.
I just Got myself a MK2 GTI Body which use to run on EFI.
The Previous Owner Butchered the Engine Bay Wiring.
I want to fit a 8V 2.0L ADY with Carburetor in the Body.
What wires will i Need to be able to get this Engine Running?
It was Originally on a Mk2 CSL Body.
I know EFi is more Sufficient But I Still Prefer Carb.
Any Help concerning a Wiring Diagram will be Appreciated
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Re: MK2 Engine Bay Wiring
Hi,
Fortunately carb doesn't really need many wires.
The main wires you would need is:
1. Power from ignition to the coil
2. WHat dizzy will you run?
2.1 Vacuum Advance Dizzy - you will require a tp100 harness and wire in the coil, dizzy and tp100 module. There's around 7 wires and pins are on google. Bear in mind if you run a vac adv dizzy, you need an adaptor plate to fit that dizzy onto the ADY.
2.2 Non Vac Adv - you will need a wiring harness and control box from a mk3 carb - this is the harder way but you get to use the dizzy that comes with the motor.
3. Power to starter that only comes on when key is cranked.
4. All important wires to cluster such as High and Low Oil pressure, water temp, water level, rev counter?
5. The carb itself requires an ignition 12v as well for the soleniod.
Not sure what you have, perhaps check and we can advise anything further.
Just a reminder you will need an adaptor plate for the carb as well to close up the injector ports on the ADY.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
Hi VWicked
Thank you for the Reply.
The ADY has all the Required Adapters.
It was running in my CSL.
Im putting the ADY in a GTi Body as mine was Smacked from the Back by a Truck.
I still have the Original TP100 & Wiring Harness from the CSL.
Will the colour coding for the Water,oil,fan and so forthed be the same in the GTi?
As the Previous Owner Hacked the Wiring on the GTi?
T Y I A
T Y I A
- VWicked
It should be the same.
Yellow, red trace is water temp. Blue wire and white wire for oil pressure sensor. Fan wiring is seperate piece mostly red with black trace.
Thank you.
Will have a look into it. will be doing the Rebuild this Weekend.
Im holding Thumbs that all will work out
And then on the carb one power wire for the shutoff solenoid. Can source that form the coil positive which should be switch on with the ignition.
Thanx Panic.
You guys are Legends.
Just a quick one the rear Gearbox Bracket where can I get one?
As mine Broke in the Accident.
oooh. Scrapyard....
- grease monkey
- Car Make: Golf
- Car Model: MK2
Yes Grease Monkey that one.
Ill pay it. where you situated?
- grease monkey
- Car Make: Golf
- Car Model: MK2
Primrose Germiston. Will message you my number, let me know if you dont get it
I work in Wadeville.
Closeby
Closeby
Thank you for your Help Guys. Will post Rebuild with some Pics.
Got my work cut out for me.✌
- VWicked
Point 5 above...panic-mechanic wrote: ↑Tue Oct 02, 2018 10:28 am And then on the carb one power wire for the shutoff solenoid. Can source that form the coil positive which should be switch on with the ignition.
How do you add Photos?
Struggeling a bit
Struggeling a bit
- Voora Molester
yummy
Please post more pics as you go along.
i will do.
Quick Question. what you guys think about using copper Spray on Intake & Exhaust Gasket when Fitting new ones?
copper gasket maker or what exactly are you talking about. Exhaust maybe - no need on intake
i have got copper Gasket Spray. its a gasket maker in a Tin.
Thought of using it to create a proper Seal on intake & Exhaust
If you use a proper gasket on the intake it is almost never needed. All it will do is making it hard to take it apart next time.
Got the new Body on Saturday. Lots of work waiting. But very Excited.
I still have my old 5 Door for some Donor Parts.
The New Body has a Sunroof. but Roof Lining sagged.
How difficult will it be to remove roof Lining from Donor Body to fit new body and to Cut out Sunroof?
The Donor Roof Lining is not Material covered. Don't know how to Describe the roof. but it feels nice & hard.
As this is my first ever Rebuild of a Body.
So there might be a couple of Questions that I will ask during the Reassembly and Fitment of all the Parts.
TYI
TYI
