HEsitation on acceleration
Gummi
Car Model: Mk4 Jetta V5 AGZ
Post by Gummi »
Hey guys
Anybody give me and idea on what woulkd cause a very, very slight hesitation when with gentle ecceleration? Suspect vehicle is a V5 AGZ. No faults came up with vagcom
Re: HEsitation on acceleration
how long a list do you want?.
possibilities is lean running
bad coil
spark plug
airflow meter reading wrong
cv joint
many other possibilities.
really impossible without
a) feeling it
b) doing some diagnosis like checking air/fuel ratio for a start.
Gummi
Post by Gummi »
panic-mechanic wrote: Sun Sep 30, 2018 7:24 pm how long a list do you want?.
bad coil
spark plug
cv joint
a) feeling it
Eeerm
I had a fault code, cant remember what fault code it was, that never popped up with a stupid Android app and bluetooth dongle i was using. Buddy of mine plugged in his vagcom cable and it showed up. Infact, that error as well as several others showed up. Replaced the new maf with the old one, which I just cleaned and problem sorted.
DONT BY CHEAP ANDROID TYPE ELM 327 THINGIES! Its useless!
AND STAY AWAY FROM CHEAP MAFS!
