Gents.
I need some help here. Im not getting 12v to the maf on my v5 agz. I get my ground and 5v but not the 12v with the ignition on. Pls can someone point me in the right direction.
No 12v on maf
- Car Model: Mk4 Jetta V5 AGZ
Re: No 12v on maf
Try testing with the car idling, i doubt the ecu would want a maf reading if the engine is off
Re: No 12v on maf
Ignition on engine not running.
Have you gone through all the fuses.
And are you sure it should have 12v. Not every single maf out there has 12v.
Re: No 12v on maf
Panic Mechanic! The man.
I picked up a error when I had it scanned yesterday. Car also always felt a bit sluggish. Anyway, the only info I could find was on autodata. I have the 4 wire maf, and it says there that there should be a 12v, 5v, Signal and ground. I get the all except the 12v, with ignition on. I have gone through all the fuses yes. I find very little info on the net regarding a V5.
Re: No 12v on maf
If I had not managed to break my elsawin I could have looked at the wiring diagram.
Re: No 12v on maf
Its all good Panic. I cleaned the old maf with switch cleaner and put it back on again. Im seeing the guy later today again to have a look at what vagcom says. I will keep you guys updated.panic-mechanic wrote: ↑Fri Sep 21, 2018 10:47 am If I had not managed to break my elsawin I could have looked at the wiring diagram.
