Polo vivo epc issue
Polo vivo epc issue
Howzit guys so I got a 2010 polo vivo 1.4i (CLP)
I'm experiencing a problem where the epc light comes on and the revs pick up to roughly 1200rpm, the car idles rough and there accelerator becomes unresponsive, I'll
Have to switch of and start again.
So far I've cleaned the throttle body.
And the plug that goes into the throttle body.
No luck.
Please help
No luck.
Please help
- Unobeat
- Car Model: Uno, Auris, CX-5
Re: Polo vivo epc issue
Hello and welcomeMohamed.f wrote: ↑Thu Sep 20, 2018 10:38 am Howzit guys so I got a 2010 polo vivo 1.4i (CLP)
No luck.
Please help
Some reading here:
viewtopic.php?f=92&t=211971&p=2565791&h ... e#p2565791
viewtopic.php?f=92&t=201934&p=2489608&h ... e#p2489608
- Car Model: Mk2 GTS
Hi, get it diagnosed first.
S4 2004 --> Stock
A3 2010 1.8T Cabrio --> Stock
Previous
Golf Citi 2.0 8v MP9 2007
Jetta 4 V5 10V
Honda CB400 '74
S4 2004 --> Stock
Previous
Jetta 4 V5 10V
Honda CB400 '74
EPC light appears after about 5 seconds after the car idles smooth on my polo vivo I've had the cam shafts replaced rockets,oil pump and lifter and put a new map sensor but still the same problem even a new timing chain kit need help please
Hi did you do a diagnostic on the car before you changed all of that?SLOMBERJACK wrote:EPC light appears after about 5 seconds after the car idles smooth on my polo vivo I've had the cam shafts replaced rockets,oil pump and lifter and put a new map sensor but still the same problem even a new timing chain kit need help please
- Car Make: Nike
Agree get it on VCDS. Get Codes take it from there.mellos wrote: ↑Mon Jul 22, 2019 8:07 pmHi did you do a diagnostic on the car before you changed all of that?SLOMBERJACK wrote:EPC light appears after about 5 seconds after the car idles smooth on my polo vivo I've had the cam shafts replaced rockets,oil pump and lifter and put a new map sensor but still the same problem even a new timing chain kit need help please
Post your location. A lot of guys willing to do scan for free Including Myself.
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
Hi Guys, my epc light on my vw polo vivo just came on and wont go off.. engine feels fine with power etc. Can someone assist me?Rudi46 wrote:Agree get it on VCDS. Get Codes take it from there.mellos wrote: ↑Mon Jul 22, 2019 8:07 pmHi did you do a diagnostic on the car before you changed all of that?SLOMBERJACK wrote:EPC light appears after about 5 seconds after the car idles smooth on my polo vivo I've had the cam shafts replaced rockets,oil pump and lifter and put a new map sensor but still the same problem even a new timing chain kit need help please
Sent from my SM-A205F using Tapatalk
- Car Make: SEAT
Are your brake lights working properly?@Rikesh-R wrote: ↑Wed Jul 31, 2019 8:34 pmHi Guys, my epc light on my vw polo vivo just came on and wont go off.. engine feels fine with power etc. Can someone assist me?Rudi46 wrote:Agree get it on VCDS. Get Codes take it from there.mellos wrote: ↑Mon Jul 22, 2019 8:07 pmHi did you do a diagnostic on the car before you changed all of that?SLOMBERJACK wrote:EPC light appears after about 5 seconds after the car idles smooth on my polo vivo I've had the cam shafts replaced rockets,oil pump and lifter and put a new map sensor but still the same problem even a new timing chain kit need help please
Hi im sorted. Brake lights were not working. Changed the globes and boom it works again and epc light goes off.. alternate was to replace the brake light switch. But not neccessary at this moment. Thanks
- Membership No: 2033
SLOMBERJACK wrote: ↑Sun Jul 21, 2019 1:20 pm EPC light appears after about 5 seconds after the car idles smooth on my polo vivo I've had the cam shafts replaced rockets,oil pump and lifter and put a new map sensor but still the same problem even a new timing chain kit need help please
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Very crazy all those engine parts replaced for brake lights not workingHowie-WP wrote:SLOMBERJACK wrote: ↑Sun Jul 21, 2019 1:20 pm EPC light appears after about 5 seconds after the car idles smooth on my polo vivo I've had the cam shafts replaced rockets,oil pump and lifter and put a new map sensor but still the same problem even a new timing chain kit need help please
diagnose diagnose diagnose
My Polo vivo 2013 EPC Light on - Misfire Piston 2. Had the car at Auto electrician 9 times, replaces electric wires. Still unresolved.
When cold the EPC ligh goes on and engine then cuts one cylinder.. loss of power and engine ideles uneven ... Stop engine switch it off.. restart no light car fine, Then it reoccurs until engine hot. Next day the same story, however, the frequency is now increasing.
In the interim changed PencileCoils, Plug
Then took the car to VW. - VW said engine must be opened..... +-38K. They say might be valve seals or piston 2..... no smoke. Oil fine... What can it be?
BENALLEN wrote: ↑Tue Sep 03, 2019 1:59 pm My Polo vivo 2013 EPC Light on - Misfire Piston 2. Had the car at Auto electrician 9 times, replaces electric wires. Still unresolved.
Compression test will go some way in finding the answer.
Did vw do that?
Recommend a compression test and take it from there. Could possibly be an issue with the piston or valve/valve guide which results in drop in compression on that cylinder
