Jetta v5 abs light
Gummi
Car Model: Mk4 Jetta V5 AGZ
Jetta v5 abs light
Post by Gummi »
Backing into the driveway last night i heard a woosh sound, kinda like a tyre deflating. Checked tyre and ut seemed okay. On my way to work this morning the abs light came on a minute into the drive.
Got to work, switched off the car, turned ignition on, abs light went off as per usual. I then started and let the car idle for about15 mins and no abs light. It only comes on while driving.
Any ideas pls
Gummi
Re: Jetta v5 abs light
Post by Gummi »
Thought i would let you guys know, should anybody be interested. Found the problem with my ABS situation, turns out it was a intermittent 30A fuse by the battery.
