Mk3 GTi engine issue
- noor
hope someone can help me out as i am completely baffled. i know i don't drive my car much and it parks off for 6 - 10 months each year with me only driving it when ever i get a chance meaning only in summer. however, one thing i never skip out on is servicing my GTi annually. for those who don't know my car,its a Golf Mk3 GTi 2door with the 2E long block engine. what i did this year was replace my fuel pump, replace the fuel filter, replace the usual items like spark plugs, oil, air filter, etc. i needed to replace my fuel pump as i could smell the fuel inside the tank was off so therefore drained all the fuel since when i started the car, there was no power and it idled very erratically and appeared to idle only on 2 cylinders.
after replacing all these items the car still idles only on 2 cylinders (1 and 3). the cylinders 2 and 4 isn't working for some reason. i already checked for spark and across all 4 cylinders its definitely there (pulled out plugs from spark plug to see for spark) however, removing the plugs for cylinder 2 and 4 makes no impact on idling of the car.
anyone have any ideas as i am completely baffled...
VW Golf Mk5 GTi DSG
VW Golf Mk3 GTi 3dr 2litre 8V
ex - VW Jetta Mk3 CLi Exec 2litre 8V
ex - VW Jetta Mk3 VR6 3.0litre 12V
- noor
Re: Mk3 GTi engine issue
do you think it is the injectors? remember this engine has Bosch engine management system, not MP9... and if it is the injectors would i need to strip it and have it cleaned to see whats wrong? remember the fuel is getting to the injectors as everything before the injectors have been replaced and is working 100% as i did a check as well by swopping fuses causing the fuel pump to remain on when ignition is on which allowed me to easily drain the fuel tank...
VW Golf Mk5 GTi DSG
Did you remove the spark plugs as well and check that all four spark while cranking the motor?
A buddy had some issue with his Mk3 CLI and we checked the injectors by removing the whole fuel rail and placing a old towel under the injectors, then cranking. It was another issue, but we managed to at least check that it was getting fuel.
- noor
yes i confirmed all 4 spark whilst cranking the motor - so it means i need to remove the injectors and fuel rail... my worst nightmare...Jetta2 wrote: ↑Tue Sep 04, 2018 12:13 pm Did you remove the spark plugs as well and check that all four spark while cranking the motor?
VW Golf Mk5 GTi DSG
- Membership No: 2033
Moral of the story, drive the car more ......
GLWF .......
GLWF .......
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- noor
yeah but i know guys who drive their cars once a year as well and no issues and have been doing so for years...
VW Golf Mk5 GTi DSG
- noor
so i guess nobody has any info on what could resolve my problem????
VW Golf Mk5 GTi DSG
No - YOU need to do some diagnosis ie have the injectors checked. Nobody else can just simply give an answer to why it's happening without seeing the car or you giving some feedback.
- noor
thanks much appreciated - i have been hectic busy with work but plan to sort the engine out october - will be getting a buddy who works for VW to pop over to me and then we can have a look..panic-mechanic wrote: ↑Wed Sep 05, 2018 7:14 am No - YOU need to do some diagnosis ie have the injectors checked. Nobody else can just simply give an answer to why it's happening without seeing the car or you giving some feedback.
VW Golf Mk5 GTi DSG
- noor
finally had a check on the injectors and its the fuel rail, only injector 1 and 3 working but 2 and 4 isnt. had the complete fuel rail removed and taken by my buddy to VW and inserted into an ultrasonic bath to clean it. seems that didnt work as when we fitted it back problem still there, engine cranks but backfires like crazy and sounds like only 2cylinders working.
then tried to source another complete fuel rail - seems its NLA (no longer available). i tried all the parts shops like Mikes Place, Goldwagens, 786 Spares, VW Spares, etc and none of them have this 2E Bosch fuel rail.
so how hard is it to fit an Mp9 fuel rail onto a 2E engine? I doubt it will work but i previously owned a jetta CLi exec with the MP9 2litre 8V engine and the head seems the same from the pics I took. this digifant engine seems like it was a problem child no wonder VW SA opted for something different...
any help appreciated...
VW Golf Mk5 GTi DSG
You could fit the rail but the injector values might not be right. mp9 has individual injector wiring and the resistance might be wrong when you put them all together. You'll have to do some measurements. And then I also have no idea what CC flow the 2E's are - have never needed to find out.
Put a wanted post on - somebody will have one somewhere.
- mike65
- Car Model: mk1
Seems like your injectors is and issue...have the injectors cleanednoor wrote: ↑Thu Nov 22, 2018 3:02 pm finally had a check on the injectors and its the fuel rail, only injector 1 and 3 working but 2 and 4 isnt. had the complete fuel rail removed and taken by my buddy to VW and inserted into an ultrasonic bath to clean it. seems that didnt work as when we fitted it back problem still there, engine cranks but backfires like crazy and sounds like only 2cylinders working.
Watch this space
- EX-DOHCTOR
- Membership No: 712
Locally I would try obvious places like scrapyards or anywhere that imports engines. Otherwise you'll need to try find NOS (new old stock)
Try Graham Savage from Goldwagen JHB CDB, his inventory or old/hard to find parts is massive.
If all local suppliers fail, it's time to look internationally:
https://www.vwheritage.com
If they don't have you can also look on fakebook for a group called Merseycabriobreakers. They should be able to source what you need from their stock or donor vehicles.
Expect shipping to cost more than the parts though, so put in a big order for everything needed on the car to make it worthwhile to import.
Otherwise you can also try VWVortex.
Post a picture of your rail and injectors. Chances are that someone may have what you need.
- noor
thanks and i managed to import a complete fuel rail for R750 from uk and ended up paying R350 for shipping plus R150 for customs/excise duties. fitted it and engine started perfectly first time round - all sorted now. thanks to all for the help...EX-DOHCTOR wrote: ↑Fri Dec 07, 2018 10:02 am Locally I would try obvious places like scrapyards or anywhere that imports engines. Otherwise you'll need to try find NOS (new old stock)
VW Golf Mk5 GTi DSG
- EX-DOHCTOR
Glad you got her sorted. Now how about some more photo's?
