Hi, wondering if someone can help, our 1600 caddy struggles with cold start, if you press the accelerator when starting it doesnt start and when you just start without pressing the accelorator it start but runs lumpy almost as if there is a plug dead and if you press the accelorator then it gives a cloud of smoke, it only do this for about 15 seconds then it run perfect again.
Any advice?
Caddy 1600i lumpy on cold start
- Armand
- Car Model: Black Magic 6R Polo Gti
- Membership No: 1828
2011 Black 6R Polo Gti (Forge intake, Viper dp, Stage 2 DNA sw)
2007 Polo gti (Giac software, 76mm dp, ITG Induction, custom FMIC)
2009 Citi 1.4i sport
1997 Uno turbo ( w/m, Tdo4 turbo, intercooler,76mm exhaust
Bmw 540i e34 (Standard)
Nissan 3.0 v6 (Brospeed branches and exhaust)
2009 Polo gti (Giac software)
Suzuki gsxr1000 k5 (Everything)
Vw caddy club (Mp9 conver, Branches, exhaust, chip)
Re: Caddy 1600i lumpy on cold start
Possibly a leaking injector..?
- Armand
How can I test them?
There are a few ways to test them but they require special tools or a jig..
I guess a simple way would be to remove the rail with the injectors, pressurize the system and check for leaks.. if im not mistaken the mp9 injectors have clips holding the injectors in place so they wouldnt push out from the pressure..
Or before u start it after sitting for a long period, disconnect the injectors then remove the plugs and swing the engine. If u see fuel vapour coming out the plug holes then u know its leaking
start by changing the water temp sender. Then worry about other stuff if it does not fix it.
- Armand
Thanks, I am going to try that water temp sensor and report back
