Car starts perfectly n idles but if u rev it it will switch off after it comes backdown the rev counter...also while driving it has a kickback before finally getting its power back an switches off when slowing down or stopping at stop streets or robots
It's a brand new carb that's fitted
Also noticed that when turning on the ignition just to the on position without cranking the engine the rev counter bounces a few times sometimes up to 4 thousand revs
Any ideas on what I'm dealing here with
JETTA 2 1.8 carb issues
- Car Model: G1 2l 8v
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
JETTA 2 1.6 (STRIPPING FOR SPARES)
Call for what u want
JETTA 2 1.8 (customer repairs)
Front smash
OPEL CORSA 1.4 LITE ( customer repairs )
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
- Ryandevraj
- Car Model: 1988 Citi Golf 1.8
Re: JETTA 2 1.8 carb issues
your dizzy timing could be wrong as its overly retarded or i would also look at vacuum leaks, did you change your base plate when replacing the carb?is it an orginal carb or pirate?
Sounds like a spark issue rather than fuel
