Dyno Figures
- FrAnKeNsTeIn
- Car Model: POLO GTI
Dyno Figures
Good Day People,
I need a bit of advice or your opinion.
I bought a vw aba motor from someone and then fitted it in a velocity, the specs are as follow:
Engine has been stroked to 2.1L
TDI crank
2.6 caravelle pistons
gasflowed head
276 cam and adjustable vernier pulley
50mm exhaust with 2 boxes.
ff gearbox.
I ran the car on the mp9 system with a 2l flash.
I then sent the car in to have a dictator fitted at a well known and reputable guy, and got it back this morning after waiting almost a week for the car
Looking at the dyno sheet, it only managed to make 75kw. Is this the correct number or was I just to excited?
And please, I am not bad mouthing the tuner.
Any assistance will be appreciated.
TDI crank
gasflowed head
ff gearbox.
2008 VW Polo GTi 1.8T
Uni Stg 1, Downpipe, Intake.
- ICE King
Re: Dyno Figures
Seems right considering you at highveld making 75kw @ 5500 ATW?
Ask your tuner why is the car limiting @ 5500 and the power dieing a 5000 already?
The power you looking for is after 5500.
- FrAnKeNsTeIn
Re: Dyno Figures
Thanks,
Any suggestions on increasing the power? I was expecting close to 100kw with those mods.
Currently i am struggling to choose between going the turbo route or staying Na.
- ICE King
Re: Dyno Figures
Not sure what brand of Cam you using but there are brands to stay away from , Esta's is a good make.
Getting 100kw ATW wont be easy but is possible.
Next step would be branch and 63mm exhaust, 288 Esta Cam, I suspect your exhaust system is the reason for the power dieing after 5000rpm. Is it free flow boxes?
- FrAnKeNsTeIn
Re: Dyno Figures
Cam is a estas cam
Those are freeflow boxes
- Donavan
Re: Dyno Figures
Limiter seems a bit on the low side.
I know a guy with almost the same mods and his rpm limit is set to 7800 rpm.
If I remember correctly he made 101 kw.
Audi A4 B8 2.0T - Daily
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Re: Dyno Figures
Power seems decent for your mods. What map is on the mp9, a custom or just one of those polocup maps? If its the latter then there might be room for improvement there. Also a 276 is a bit on the mild side for a 2.1.
Re: Dyno Figures
Says it has dictator on now. Seems low for those mods and you definitly need to rev it higher than 5500.
- Fidgeter
Re: Dyno Figures
How does the car feel on the road? Is there any power difference from the mp9 2lt map?
2005 Citi Golf
Current mods: 2lt 8v Single throttle
Estas cam
Branch with 57mm exhaust
Estas cam
- General
- Car Model: Golf GT
- Membership No: 1464
Re: Dyno Figures
Sybie uses his Dyno primarily as a tuning tool so the figures may look low (stingy Dyno), best would be to do a power run on another Dyno and see if the figures corresponds - I always used KAR performance to do power runs to get and idea of how much power I gained or made after modifications - as far as Dyno readings go KAR gives pretty much the same readings as HM Auto or 8VPerformance for instance.
Current rides:
Hyundai - 1.4 Getz (daily)
- FrAnKeNsTeIn
Re: Dyno Figures
They loaded a polo cup map on to the mp9.
Car pulls you more back into your seat after fitting the dictator, but dies down it the high rpm range. Car is also revving easily past 7000, don't know why they only ran it to 5500rpm on the dyno.
- Fidgeter
Re: Dyno Figures
As the guys said maybe dyno somewhere else and see your figures. Im pretty sure that was a very stingy dyno.
2005 Citi Golf
Estas cam
Estas cam
