hi gents im Chris new to the forum and in need of help with my citi golf 1.4I.
Posted: Thu Aug 09, 2018 8:31 pm
by Citi golf Chribo
I have a problem with my citi golf it does not wana start and there a buzzing noise coming from the fusebox so today I check and to find its the relay 53 situated under the dash driver side so I replaced it and car started perfect and switched of and start again perfectly fine so I decide to visit my dad and after visiting It time to leave so I try to start car swings second attempt I try to start the buzzing noise again from the relay and car wont start so I tried again this time with me trapping brakes while starting... the car decides to start so im confused I switch of agian try to start nothing.. tried trapping the brakes and start nothing but a buzzing noise when turn the key.
Please help advise what could be the problem as this is happening the first time please gents
Thanks guys
Re: hi gents im Chris new to the forum and in need of help with my citi golf 1.4I.
Posted: Fri Aug 10, 2018 2:23 pm
by Fidgeter
Sounds like a earthing problem. Maybe check under the peddles and dash if theres loose wires touching?
Posted: Sat Aug 11, 2018 3:29 pm
by PapaJo
Definitely a wiring problem. Most likely a bad earth connection.
Posted: Fri Aug 17, 2018 10:26 am
by Citi golf Chribo
hi Gents ok I figured out when it does not want to start and the relay starts buzzing behind the dash I have to open the bonnet and remove the + terminal from the battery connected to the solenoid or starter and then connect it back to the battery ( battery is brand new bought it 3 weeks ago ) battery clinic tested the battery and its fully charged ,alternator charging the battery too.. what I notice when it doesn't start and the relay (53) is buzzing my central locking sounds week like the battery is going flat, I thought it could be my alarm but I doubt it could it maybe be the solenoid / starter ? will diagnostic and multi- meter machine pick up the problem ?
thanks for your help guys
Posted: Fri Aug 17, 2018 10:27 am
by Citi golf Chribo
*weak
