Hi all.
I was hoping someone could assist, so my VW MK1 engine ceased and I eventually had it fixed. However now that I got it back it's been struggling to start and I'm not sure if it is because of the new parts.
Earlier today my car started perfectly fine first time round, but now when I wanted to go out again today my car started fine using the choke as I normally do . My engine stalled while idling , I pulled the choke out and started it again . It ran for 10 seconds and died again from a cold start . I tried starting it again and my car just won't turnover . I'm not sure if it may be flooded from too much fuel from trying to start it too many times?
Please help if you can I'd really appreciate it!
VW MK1 won't start again
Re: VW MK1 won't start again
Well remove the spark plugs and turn it over by hand first. If it does not then something went wrong.
- Car Model: Chico
Change your temperature switch..that device on a pipe that is connected to the engine..it has four pins
- chucker02
- Car Model: Citi ADY
That wont cause it not to turnTebzaGolfboy wrote: ↑Fri Aug 10, 2018 7:42 am Change your temperature switch..that device on a pipe that is connected to the engine..it has four pins
1971 VW beetle
1971 VW beetle
- Fidgeter
Could be your carb baseplate is cracked? common issue... maybe check that out
2005 Citi Golf
Current mods: 2lt 8v Single throttle
Estas cam
Branch with 57mm exhaust
Estas cam
He says it won't turn over. Neither a temp sender or a carb base plate will cause that.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
It will still start, with a miss...Fidgeter wrote:Could be your carb baseplate is cracked? common issue... maybe check that out
Sent from a phonebooth in Hillbrow
Turn motor by hand at least 3 times, 19 spanner on crank pulley. If all is well with no audible "knock" check for spark and fuel and timing just to be sure..
If that checks out pour a cap full of petrol into carb and swing...
Does ur car have ac fuel pump or electric?
