Mk3 GS 1.6 Carb
SDAYA
Mk3 GS 1.6 Carb
Post by SDAYA » Wed Jun 20, 2018 8:00 am
Morning guys,
So I'm tired of cold winter mornings cause my car refuses to start
I spray quick start and it starts, but instantly dies.
The cery same day in the afternoon when I can get back from work the car starts at first swing.
I swear it's like two different cars.
Not sure if it's a carb related issue.
So I'm thinking for converting to 2.0L MP9 or even just converting my current motor to MP9.
Anyone that can assist?
Want to know how much for supply and labour would cost or a place that I can contact for a quote?
Sean Trollope
Car Make: VW. Hyundai.
Car Model: Citi golf. Hyundai i10
Re: Mk3 GS 1.6 Carb
Post by Sean Trollope » Wed Jun 20, 2018 8:30 am
Right so there is this magical device called a choke
SDAYA
Re: Mk3 GS 1.6 Carb
Post by SDAYA » Wed Jun 20, 2018 8:32 am
Choke doesn't help
Whether I pull it out slightly or full
Sean Trollope
Re: Mk3 GS 1.6 Carb
Post by Sean Trollope » Wed Jun 20, 2018 8:34 am
Check that the tension in the cable is correct.
SDAYA
Re: Mk3 GS 1.6 Carb
Post by SDAYA » Wed Jun 20, 2018 9:31 am
It opens and closes the flap as you either pull the choke in or out.
Re: Mk3 GS 1.6 Carb
Post by panic-mechanic » Wed Jun 20, 2018 10:09 am
It's clearly a fuel,supplybissue if it starts with quick start.. So check th carb base plate and check the pump that it delivers fuel.
Put you hand on top of thencarb and let somebody crank it. See that a decent vacuum is pulled. Ie no leaks in the intake side.
Then also adjust the idle mixture to be richer
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
SDAYA
Re: Mk3 GS 1.6 Carb
Post by SDAYA » Wed Jun 20, 2018 11:14 am
If its a fuel supply then wouldn't it struggle to start in the afternoons
It's only cold mornings or cold evenings
If the temperature is okay then it starts with no issue
SDAYA
Re: Mk3 GS 1.6 Carb
Post by SDAYA » Wed Jun 20, 2018 3:44 pm
What's a cold start switch and can that be an issue?
Re: Mk3 GS 1.6 Carb
Post by panic-mechanic » Thu Jun 21, 2018 7:01 am
What is cold start switch? Don't know such a thing.
A warm engine needs a lot less fuel. But hey rather keep guessing and or sell it than try a few of the things I suggested.
'09 Audi Q5 3l tdi
VAG Fan
Re: Mk3 GS 1.6 Carb
Post by VAG Fan » Thu Jun 21, 2018 9:09 am
Have you tried giving small pumps on the accelerator pedal while swinging the starter?
Does it eventually start in the mornings?
And if it does, how does it run?
Is there any smell of unburnt fuel?
I ask this because even at freezing temperatures, I can start my Fox (carb 1.6) without the choke, if I must.
PoloMike
Car Model: 1998 Polo Classic 1.8
Re: Mk3 GS 1.6 Carb
Post by PoloMike » Thu Jun 21, 2018 9:15 am
Are you spraying the quickstart directly into the carb or up the intake pipe( filterbox)?
1998 Polo Classic 1.8 with added "benefits" :violin:
SDAYA
Re: Mk3 GS 1.6 Carb
Post by SDAYA » Fri Jun 22, 2018 9:53 am
So the issue was the carb itself...
I put another carb in and car is better than ever!
Did timing as well and adjusted the carb accordingly so now car starts with no issues and also has alot more power.
