Noisy Tensioner
sheheen29
Car Model: Golf 1
Noisy Tensioner
Post by sheheen29 » Tue Jun 12, 2018 9:18 pm
Hi Guys
I recently noticed that my 8v cam belt tensioner starting to wind after driving the car hard, especially when revving the motor its a very audible noise.
Just wanting to find out will anything go wrong if I continue driving the car with the noisy tension or should I get it changed asap?
Golf 1 2lt 8v (Crossflow)
43mm throttles
57mm Zorst 298 estas cam
Dictator Management
GTS Tuned
124kw and 191nm- pump fuel
Nadz mk1
Car Model: Mk1 2dr
Re: Noisy Tensioner
Post by Nadz mk1 » Tue Jun 12, 2018 9:51 pm
How old is it? Why not change it including the belt
82 mk1 2dr
1984cc carb fed
81kw - 203nm @RBTS
sheheen29
Car Model: Golf 1
Re: Noisy Tensioner
Post by sheheen29 » Wed Jun 13, 2018 7:08 am
Not sure how old it is. I got the motor in the car for 10 months and just recently the noise started.
43mm throttles
Dictator Management
GTS Tuned
dcmk4
Car Model: MK4 GTi
Re: Noisy Tensioner
Post by dcmk4 » Wed Jun 13, 2018 8:02 am
Would be worth doing a cambelt change in that case, it would only get noisy when it starts to wear out and the last thing you want is the tensioner to seize when driving and eat the cambelt.
'03 Golf Mk4 BT GTi
Re: Noisy Tensioner
Post by panic-mechanic » Wed Jun 13, 2018 12:02 pm
Change it with a new belt asap.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
sheheen29
Car Model: Golf 1
Re: Noisy Tensioner
Post by sheheen29 » Wed Jun 13, 2018 8:56 pm
Thanks for the replies. I will have it sorted out soon.
43mm throttles
Dictator Management
GTS Tuned
