Hi Guys,
I need some help. My car seems to have a power dip for a split second. It is really annoying as it is happens unexpectedly. The rev counter would fluctuate while in motion then the dip would happen. I have replaced the battery about 2 weeks ago. What could be the cause?
2nd issue - whenever i switch the car off after long periods of driving in the traffic then then the water would overflow. I have replaced the waterpump and radiator on friday and the issue still persist. Also my heat gauge not functioning properly. The heat gauge would remain on 50 and would move 1mm and then the fan activates. Faulty fan switch?
Car: citi1.8i, 2007 model
Thank you in advance.
Intermittent loss of power and losing water
Re: Intermittent loss of power and losing water
these are those kind of problems that nobody can give you a clear simple answer without YOU having to do some fault finding.
The rev counter dip can mean a hall generator issue or can be a ignition switch or can be lots of other things that causes a break in power supply to the coil or ignition system.
For water - you need to feel if the bottom pipe is hot so does the thermostat open - also make sure there is a thermostat. try changing the water temp sensor.
Hi there i have the very similar problem, my car polo DTI 1.9 switch the engine off while im driving, and i have to wait for 10 -15 minutes and its start again. i really dont know what to do. i have changed disel pump, filter new battery, new glow plugs.
i really need help- and when i opend the front the engen is HOT....
engines at operating temp will be almost 100 degrees so that is kind of a bad measure or impossible to gauge if you have an issue by you saying it's hot.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
my_citi1.8i wrote: ↑Mon May 28, 2018 10:22 am Hi Guys,
Sounds like your distributor needs to be changed as the Hall sender saying goodbye.
- Membership No: 1919
Coil for power dip and O Ring on the water issue, had these issues on my Polo and G2 Gtimy_citi1.8i wrote: ↑Mon May 28, 2018 10:22 am Hi Guys,
Polo (9N3) GTI
Polo (9N3) GTI
