Hi Guys
I need some advice...
I purchased a can of Liqui Moly octane booster for my NA 2l 8v just to see if there’s any difference, however I’m running dictator and the car is not tuned for octane.
Will the map get corrupted if I use the octane booster or is it safe. I just had the car tuned 2 months back don’t want anything to go wrong.
Octane Booster
- Car Model: Golf 1
Octane Booster
Current Toy:
Golf 1 2lt 20v Throttles
Methanol Only
Dictator Management
8500RPM Monster
Daily:
Golf 4 GTI
76mm Downpipe
63mm Zorst
FMI
Intake
Methanol Only
Dictator Management
8500RPM Monster
Daily:
Golf 4 GTI
76mm Downpipe
63mm Zorst
FMI
Intake
- Registered for: 14 years
Re: Octane Booster
The octane booster is boosting the fuel octane. If your car was properly tuned, this should not affect the motor in a great way as it boosting the octane quality on your fuel resulting in a better combustion. Having that said, it do so at your own risk and mix in on the recommended ratio.sheheen29 wrote: ↑Fri May 18, 2018 10:52 pm Hi Guys
- Rascal69
- Registered for: 16 years
- Car Model: MK1
- Membership No: 1490
Re: Octane Booster
its cheap compared to other similar products so You can try it out and see if it makes your car run smoother with the added octane but you may not see any power gains...
We use this liqui moly octane plus with every tank in our M cars as the stock S54 M motor pings on cold start. Even though this octane booster only bumps octane up 1 point and not 10 like ultra but it still makes the cars run much better and doesn't ping or misfire. Also the stock ecu can also accommodate for it in our case...
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
- Tman21
- Car Model: BosPolo
- Membership No: 3247
Re: Octane Booster
Octane booster can not do anything to alter your ECE/MAP.
Changes fuel characteristics and nothing else. (in your case)
#TMAN21
#TMAN21
- Fuel Additive Specialist
- Car Make: Subaru
- Car Model: STi 6 Type-RA 555 V-Limited
Re: Octane Booster
Running the Octane Booster will not affect your dictator, so you can safely run it without any fear of damage to the engine or management.
That being said, Dictator is not an adaptive ECU, so the difference you will feel will be negligible.
@Rascal69 : Remember, NF doesn't only make Ultra... we have NF Street Octane Booster (3 Octane increase) and NF Super Street Octane Booster (4 Octane Increase & Injector Cleaner) that provide excellent octane boost for your buck.
- Rascal69
- Car Model: MK1
Re: Octane Booster
I am aware and have used the Blue, black and red bottles as well...NF. wrote: ↑Mon May 21, 2018 8:56 am @Rascal69 : Remember, NF doesn't only make Ultra... we have NF Street Octane Booster (3 Octane increase) and NF Super Street Octane Booster (4 Octane Increase & Injector Cleaner) that provide excellent octane boost for your buck.
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
- Car Model: Golf 1
Re: Octane Booster
Thanks guys. Atleast I have peace of mind now so I’m definitely going to try it out.
Current Toy:
Methanol Only
Dictator Management
8500RPM Monster
Daily:
Golf 4 GTI
76mm Downpipe
63mm Zorst
FMI
Intake
Methanol Only
Dictator Management
8500RPM Monster
Daily:
Golf 4 GTI
76mm Downpipe
63mm Zorst
FMI
Intake
- P1LAYA-ZN
- Car Make: Audi, VW and Toyota
- Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Re: Octane Booster
I have a 20L Toluene that I got from a Supplier, is it safe adding it to normal unleaded fuel to up the Octane ?
I think Toluene was 114 Octane last time I checked.
Anyone used this before ?
