MK3 GS '95 DOESNT START ON COLD MORNINGS
Hi Guys
I've never had issues with my car starting at any time but lately with this cold weather it doesn't start in the morning.
The engine swings but doesn't ignite?
When I get home in the afternoon and the weather is a bit warmer then the car starts with no issue.
It's like two different cars.
Any help please?
Any help please?
- Pynoxim
Re: MK3 GS '95 DOESNT START ON COLD MORNINGS
'95 is Carburettor?
Yes
Sorry I didn't mention that
I'm not familiar with the carburetor in the Mk3. Does it have a manual or automatic choke?
Manual choke
I have to pull it out and push it back
So take the aircleaner off and see if it actually closes the flap in the carb when you pull it.
Oh and get some quick start from a spares shop. Spray it into the air intake one morning. If it fires it is fuel related. If not then spark related.
Thank you
Will try
Will try
- ☆KalaMK3
- Car Model: MK3
I pressume its the "perculator" (device mounted infront of the head/tappet cover that feeds from the fuel to itself, has a return, and then feeds the carb).panic-mechanic wrote:So take the aircleaner off and see if it actually closes the flap in the carb when you pull it.
I had a similar issue prior to the swap when I was still running carb
So yesterday in the afternoon I tried straying the car
It swinged and ran for like 2 sec each time and died out until it just swang
Not sure what the issue was
Cause each time it started I tried either accelerating or pulling the choke out but it still died
Will attempt today cause weather is better
Car never gives me trouble in the heat ..
Only when it's cold
Only when it's cold
- Car Make: SEAT
Battery on its way out?
Does a battery make nonsense during cold?
- Rascal69
- Registered for: 16 years
- Car Model: MK1
- Membership No: 1490
Yes... Get it checked or tested..
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
But then motor will not swing over.
Did you follow panic’s advise as mentioned earlier i a post?
Also check for vacuum leaks on intake and carb base plate rubber and your fuel supply to carb.
- Rascal69
- Car Model: MK1
i'm just saying its easy to check the battery... I've had many batteries fail during winter thats why i invested in a battery charger.
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Of course, batteries fail more often in winter, but one of the first symptoms of battery failure is that the engine swings too slowly, or not at all. If the engine swings normally but doesn't ignite, like the OP wrote, then there is no need to check the battery. But suit yourself...
