Hi all
Just a quick question when removing fpr from the fuel rail
does the inner pipe from the rail itself come out as well is
this normal or is the rail shot
Mp9 fuel rail
- Car Model: citi 1.4i
Re: Mp9 fuel rail
Fuel rail is broken. Get a new one.
Re: Mp9 fuel rail
Thanks will do
Re: Mp9 fuel rail
Hi again so i put in a new fuel rail but when I pinched the return line the engine still runs does this mean that this fuel rail is also stuffed internally.
What would be the best way to resolve this issue I've read that fitting an external fpr would resolve this issue how would one go about doing this what sort of fpr would I need and how do I install it if someone could give me a step by step Guide it will be highly appreciated
Re: Mp9 fuel rail
If you put a new rail it should run. You should not need to pinch anything. if you do it will just go rich as heck but should keep going. As a test the pinch thing will make a non running car to run - not kill a running car.
