Hi Guys
I replaced my old cluster ( one with Clock ) for the one with a rev counter. Now the heat gauge are not working. The red light keeps blinking and the needle is not picking up. it worked for about 3 times but not coming up all the way. Now NOTHING.
cluster change Heat gauge not working
- Registered for: 19 years 5 months
- Car Model: Touareg / Caddy / Polo / Citi
Re: cluster change Heat gauge not working
I had a similar issue with my Citigolf.
The guage worked sporadically, mostly not, but sometimes reading normal and other times half the normal reading before falling back to the far left. It did appear to work better if the car was parked out in the sun. The sender unit for the radiator fan was fortunately still performing as per normal.
I managed to source a used cluster and replaced the heat guage. Problem solved, but finding a used cluster with a working heat guage, that's the challenge. From what I have heard, these guages cannot be repaired either.
Anton van Graan
2009 Touareg 3.6 VR6
2007 Caddy Life 1.9 TDi
2004 Polo 1.6 Comfortline
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
1988 Ford Laser 1600i Sport
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
