Morning Guys
the oil buzzer keeps going off. i replaced the oil pump and both the oil sensors. What could be the reason that it don"t want to stop. it is making me crazy.
Please guys any help would be greatly appreciated.
oil light and buzzer
Re: oil light and buzzer
Low oil pressure could be the reason.
Install a physical gauge - even just temporarily to see what the actual issue is. only after that can one advise further. You are simply assuming the pressure is OK.
ok. what causes low oil pressure and how much should it be.
Worn bearings. No less than 0.85 bar at idle when the engine is hot. Around 3.5 bar when at 2500 rpm engine hot.
