Hi Guys
I got a problem of my polo it doesn't kick in the fan. I tested the fan through the battery it does work and I have also changed the control module still it doesn't go through. What maybe the problem.
Vw polo 6 fan not kicking in
Re: Vw polo 6 fan not kicking in
Did you check the fuse in the fuse box?
"I tested the fan through the battery" -----Did you test the fan direct from battery?
Did you pull the wiring from the thermos switch on the radiator and bridging the wires there to check if fan then kicks in?
