Oh no. Could be their server.
9a and pl mk1 conversion possible
- 162life-WP
- Car Model: Mk1 Life
Re: 9a and pl mk1 conversion possible
nice work bro, coming together nicely.When do u expect to fire her up???
- blou_poot
If all goes well tomorrow morning.
Sent from my RNE-L21 using Tapatalk
96' Chico 2.0 Carb
- blou_poot
96' Chico 2.0 Carb
- 162life-WP
Awesome bru. Best of luck
Good luck abd let us know once car fired up.
- blou_poot
So was busy the whole day....
Finally tried to start this evening.
However dicktator not picking up timing so will continue with the journey tomorrow.
Atleast alternator and water pipes have been sorted.
96' Chico 2.0 Carb
Just double check wiring. Possibly just a bad connection somewhere.
- blou_poot
My thoughts exactly... Will recheck everything.
96' Chico 2.0 Carb
- 162life-WP
Yeah possibly something u missed coz it should fire on the 16v start up map.
Is your 9A dissy a 4 window?
- blou_poot
Yes its a 4 window dizzy.
96' Chico 2.0 Carb
Did you manage to start?
- blou_poot
Nope was a bit demotivated.
Had a lot to do today as well... Had to take the girlfriend and my mother to town.
96' Chico 2.0 Carb
Happy women, happy life. Don’t loose motivation. You’ll get it done. Take a bit longer, but once motor starts all smikes again.
- blou_poot
Thanks for the positivity and motivation from everyone here.
Will defo get her up and running.
96' Chico 2.0 Carb
- 162life-WP
I promise u once u get her fired up u will regain all motivation again. Keep ur head up boytjie, uv gotten this far, only a little remains
- blou_poot
Yip... Small things... Wanted to hookup mp9 again... Seems easier... Lol...
I think the dizzy might be an issue... It turns very tight.
96' Chico 2.0 Carb
- 162life-WP
Are u using the dizzy that came with the motor?? Mine never came with a dizzy and I had to buy a new one. Is ur firing order on the dizzy cap correct?? I couldn't get mine to start without it being in the right order. Its 1 (top left) 2 (top right) 3 (bottom left) 4 (in the toughest spot ever bottom left)
- 162life-WP
As far as I know u will need a different throttle body (vr6 obd 2) of u rum mp9 if I'm not mistaken. Stick with the dicktator u won't be sorry bru trust me. Just look through ur wiring diagram again. What coil are u using? Have u tested for spark? Do u smell fuel when u try n fire it up???
- blou_poot
Firing order correct... Bought new dizzy,
Will recheck timing marks and wiring again tomorrow... No spark and dicktator is not seeing timing.
96' Chico 2.0 Carb
- 162life-WP
Coil??? 2/3 pin?? Tp100???
- 162life-WP
R u powering the dizzy with 5/12v??ignotion switch 12v or injector 12v???are all lights on on the dicktator not just red??
- blou_poot
Just red... Using injector positive i beleive...
No other lights turning on, using 3 pin coil.
Breaking me head trying yo figure out what might be wrong.
96' Chico 2.0 Carb
Remove dissy from head and turn rotor by hand with ignition switched on and then you measure between middle (signal wire) and negative with a multimeter and check if you get voltage. With trigger disk between hall sensor, you should measure 12V and in the window zero volt. The two outer pins must measure 12V with ignition switched on.
The dizzy signal wire is then wired to pin 1 on Dicktator and ignition output 1, yellow/black wire on pin 6 on Dicktator is wired to centre pin on 3 pin coil. The 3 pin coil has an internal trigger module. No need to use TP100.
