Hi guys im new here anyway i have searched for a while now about issues with my car but i just cant seem to find whats wrong.
After i bought the car second hand i had the car serviced at barons claremont and not long after car died. As in just while driving the car just loses power then comes to a halt. They said its the fuel pump failing. This happened 3 times already barons still couldnt find out what was the issue. Fuel pump works now but its seems it may be another issue. strangely this time it was raining and i almost think water is seeping into the fuel. What happens now is like while driving its almost feels like the fuel is starving until eventually the car cuts out. After a few minutes it started but struggling to idle and drove home keeping on a high rev. This morning however its started better and eventually drove okish until finally halting again.
Please need help guys
Fueling problem with Citirox
- Membership No: 1919
Re: Fueling problem with Citirox
Try testing with another Coil, had a similar issue however mines used to back fire, I tested and found out it was the coil. Changed it to a new one and problem was solved
Polo (9N3) GTI
Polo (9N3) GTI
You need to do some testing to diagnose the problem. Add a fuel presure gauge that you can see if the prssure is dropping or staying constant.
Without diagnosis you will keep guessing.
