Hey ya'll,
Two things:
1 - So for a while now Ive had a really soft brake pedal. It feels like my booster isn't really assisting at all. My brakes work but I have to push the pedal down really hard and far before I get adequate brakes. When I start the car the pedal does drop down a bit, does that mean the booster is working? Could I have a vacuum leak? Could it be my booster? I haven't replaced my pads and drums in a while, could it be that?
2 - Today while my car was idling i pump the brakes a bit and i noticed my rpm rose and then when i stopped they dropped quite low and then came up and stabalized. Like i could hear the rise and fall and then stabalization of the idle. Is this a vacuum issue?
Thanks thanks!
Weird booster/vacuum issue
- Ansell
- Registered for: 9 years 6 months
- Car Model: 1997 Golf 3
1997 Golf MK3 GSX (1.8 MP9)
Specs:
79.7kw at 5209rpm and 160nm at 4240rpm (Saichs Dyno)
Modifications:
Stock exhaust with one 50mm-57mm freeflow box.
Standard airbox
Standard cam
Ex: 1970 Beetle 1300 twin-port
If you don't look back at your car after you park it, then you own the wrong car.
Specs:
Modifications:
Standard airbox
Standard cam
Re: Weird booster/vacuum issue
Regarding 2:
Pumping the brakes always introduces some unmetered air into the engine via the booster. This can destabilise the idle to some extent, yes. I'm not sure what is normal for your engine, though.
- EX-DOHCTOR
- Membership No: 712
When is the last time you flushed and replaced brake fluid?
- Ansell
This makes me feel better then. Its probably normal. Thanks!VAG Fan wrote:Regarding 2:
Specs:
Modifications:
Standard airbox
Standard cam
Specs:
Modifications:
Standard airbox
Standard cam
- Ansell
Its been a couple of years, maybe like 4 years, could be even more. It was my moms car and she bought it in 2012 and i got it in 2014. I think ill give that a go. Ive been wanting to do it to be honest but never got around to it. Any idea which fluid i must use? DOT3 or DOT4?EX-DOHCTOR wrote:When is the last time you flushed and replaced brake fluid?
Ill let you know if it sorts out the issue.
Thanks!
Specs:
Modifications:
Standard airbox
Standard cam
Specs:
Modifications:
Standard airbox
Standard cam
- EX-DOHCTOR
Use Dot 4 Brake fluid.
