I have a 2003 Golf 1,6, 8 valve engine. Mileage is 229300km. Condition very good and used every day to drive to work and back (75 km / day).
When driving under very light throttle, eg. in traffic on the open road doing say between 40 to 100 kmh there is a often a jerk as if the fuel is switched off. This occurs particularly on a sligh downhill, but never on an uphill. The "economy" readout will show typically 4 l/100 km and then a jerk in the car and the reading drops to 0 l/ 100km. I have tested this many times. There is no engine cut out at all. This only occurs at very low throttle opening when the readout is in the order or 4,2 /100 km. I have tried to get it down to a lower value and have reached some 3,4 l /100 km but not lower.
I suspect that the throttle position sensing potentiometer is worn out at the very low throttle opening position and this is causing the ECU to cut off the fuel.
As a result I wish to replace the complete throttle valve body. But what about the Engine Control Unit. Could this be a problem? Fuel consumption is in the order of 7,4 l /100 km. and the car runs very smoothly except for this phenomoned at low throttle opening.
Can anyone give their opinion on this?
Thank you.
Fuel flow cut off
Jump to
- General
- ↳ General Announcements
- ↳ Club and Forum Queries
- ↳ Introduce Yourself
- Events
- ↳ VWCSA Events
- ↳ VWCSA Pictures and Videos
- ↳ VWCSA KZN Events
- ↳ Non-VWCSA Events
- ↳ Non-VWCSA Pictures and Videos
- Technical Discussions
- ↳ Technical: Motorvehicle Related Discussions
- ↳ TDI Engines
- ↳ N/A Engines
- ↳ Forced Induction Petrol Engines
- ↳ General Tech Discussions
- ↳ Technical: I.C.E. Related Discussions
- ↳ Technical: Detailing Related Discussions
- ↳ Technical: Volkswagen Vehicle Test Information
- ↳ Technical: Frequently Asked Questions
- ↳ Panic's Place
- ↳ TSC Garage
- ↳ Digit - Vehicle Tracking Fleet Management Fuel Monitoring
- ↳ Chameleon Wrap & Shine
- ↳ Auto Agent
- ↳ Crazy Detailer
- ↳ GearTronix
- ↳ Goldwagen Kensington
- ↳ Good Enough Garage
- ↳ Liatros Recycling
- ↳ KNS Customs
- ↳ Motorlease
- ↳ MMS Auto
- ↳ WheelIndex
- ↳ VAG Technik
- ↳ VAG Cafe
- ↳ RevLimit ECU tuning SA
- ↳ Racer's Edge
- ↳ Pristine Detailing
- ↳ Poor Boys
- ↳ NF Additives
- ↳ RetroFitters
- ↳ Wheels & More
- ↳ Forum Section Advertisers
- ↳ Delarey Racing Developments
- ↳ Goldwagen Delarey
- ↳ Huber Motorsport
- ↳ NF Additives
- ↳ THANAS Performance
- ↳ VW The Glen
