Hwzit guys im new to forums this is my first so take it easy on me...
Iv been driving vw's ever since i learnt how to and its only this car im having issues with...
My car was a kjet and it used to start missing and lose all power the moment i floor it when its still cold like about 50-70 degrees wen i pull off the engine dies so i hav to keep reving(press n lev acceleration) once it warms up its like 85+ its fyn....it got worse later n on start up it done that every1 sed remove kjet put sidedrafts it will b fyn but it did not help its still same problem...really appreciate help...
Mk2 gti doesnt idle when cold
- Registered for: 6 years
- Car Model: Mk2 Gti 8v
- Membership No: 1919
Re: Mk2 gti doesnt idle when cold
Did you check all breathers on the car?
Polo (9N3) GTI
Polo (9N3) GTI
I did check everything even put new pipes and intake pipes from running cli to check for a difference ... and btw its now running on a set of 40 sidies still the same issues someone sed me the wur was the issue i did a change of system for nothing but will i still need a wur if its now running off sidies?
The idle when its cold on a slight rev is like my car is super worked wid really big cams n it gradually calms down as it heats up sounds perfect them like nothing is wrong until it gets cold and startd once agen...
Another point i even replaced my bottle ign coil from stock bosch to 6series msd performance coil thinking the spark was too low for cold combustion but no luck
Sonow it's just a GT.
anyways when it was still k-jet the issue would have been that the cold aux air device was not working.
So you swopped a system that COULD actually compensate for cold idle for a system that cannot compensate for cold idle. A basic carb that has not got any choke mechanism will always be too lean on cold start and cold idle as a cold engine needs to be richer to run.
Side draught carbs has no auto or manual choke mechanisms so you are back to where you were. Live with it.
If i decide to get it injection system n running dicktator do i have any luck then?
I also have the kjet intake wich i did mod n got a 325i e30 throttle to work on it....i also have mp9 injector rail wid 250cc injectors the fuels pumps are still on the car...so do i jus need a chopped mp9 loom n dicktator/management ???
- Car Make: Vw, Bmw, Merc
- Car Model: 81 Vw Mk1 Cabrio,15 Mk7GTi
- Membership No: 3258
Howsit man, did you find a solution o. Your kjet problems or are you running injection now?
