Howzit Guys,
I recently got a DGF gearbox from a friend who confirmed it was long ratio box.
After doing research i found that the ratios are exactly the same between the AUG and the DGF box.
My problem arose after fitting the DGF box to my 1.6 1998 Polo Classic. Unfortunately I did not have the 210mm fly wheel clutch and pressure plate.
I used a 1.6 pressure plate in a 210mm fly wheel after checking if its okay to do so.
Luckily all fine clutch is okay,
I don't have cruse speed though, the car had a DGG box in before and i was getting 120km at roughly 4000rpm which was to high.
With the DGF i was hoping to get 120km at a rpm of maybe 3000rpm, but no luck with the DGF i get about 100km at 3000rpm.
What i would like to know could this be because of using a small clutch plate in the 210mm flywheel or is there something else i need to do, so I can get the 120km at 3000rpm cruise speed?
Thanks for your help in advance
AUG versus DGF ratios
- Car Model: Mk2 Jetta CLI
Re: AUG versus DGF ratios
Clutch diameter has got absolutely nothing to do with gear ratios.
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Increase the 5th gear ratio, clutch plate won't make a difference in rpm's
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
how complicated is it to increase the 5th gear ratio,
The car's DGG gearbox is not in use at the moment maybe i can amend its 5th gear ratio
