2l 8v rebuild to aleast 110kw
mike65
Car Model: mk1
Post by mike65 » Thu Jan 18, 2018 2:45 pm
Howsit guys
Is their actually like a step by step guide on how to build a more or less 110kw 2l 8v motor?
Not that i dnt know how but would just like to see how other people get there.
Im planing on :
boring to 83.5mm
fitting branch and freeflow and
doing head work then maybe change to aftermarket management at a later stage.
Ive got pricing for pistons at R1380 with goetzee rings and bore costs about R860 rest of pricing will follow
Any input on a guide would be nice maybe i can learn new things :smile:
Watch this space
billionairebum
Car Model: 1.9 TDI Sportline
Membership No: 3194
Re: 2l 8v rebuild to aleast 110kw
Post by billionairebum » Thu Jan 18, 2018 2:47 pm
Slap a 1.9 TDI 8v motor in there and klap a file = 110 to 120 kw.
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza » Thu Jan 18, 2018 2:54 pm
How much money do you have, that's gonna be key
Darryn Van Rooyen
Current: 14 Amarok BITDI D/C 4Motion H/L Auto
Current: 1987 Citi Sport 1.6
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
Post by panic-mechanic » Thu Jan 18, 2018 3:14 pm
Bore (increase capacity), raise CR, head flow , long cam, branch and freeflow , throttles. That is the normal path.
If not enough , more valves, NOS, Turbo.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
supervly
Car Model: Polo 9N TDi Sportline, Jetta V
Post by supervly » Thu Jan 18, 2018 4:15 pm
I am looking at going a similar route - but its for a T3 syncro , I have a spare 2e motor which ran bearings .
I was looking at doing the 1.9 tdi crank and 2.3 caravelle pistons and potentially a mild cam
How far can one take the MP9 mapping? , currently I am using the short loom with mp9 polo cup 2.0 computer box
I don't want crazy top end power , just more bottom and mid range power - to help climbing hills without generating too much heat
Sorry for the hi jack mike
mike65
Car Model: mk1
Post by mike65 » Thu Jan 18, 2018 4:20 pm
supervly wrote:I am looking at going a similar route - but its for a T3 syncro , I have a spare 2e motor which ran bearings .
^this im leaving for my 16v built which will be in this year as money rolls in
^Im not sure how far but with uni q you should get enough for under 120kw id say?
^ no stress, enjoying the chat :type:
Watch this space
mike65
Car Model: mk1
Post by mike65 » Thu Jan 18, 2018 4:22 pm
panic-mechanic wrote:Bore (increase capacity), raise CR, head flow , long cam, branch and freeflow , throttles. That is the normal path.
Today ive learned you get two 83.5mm pistons of which one is 63mm long and other one is shorter
Which one would suit the long block running standard crank and rods?
Watch this space
mike65
Car Model: mk1
Post by mike65 » Thu Jan 18, 2018 4:24 pm
dazza wrote:How much money do you have, that's gonna be key
Money is no issue, This will be my daily and mid range race car so as time goes on i will upgrade and build a 16v later on
Watch this space
Neuk
Treasurer
Treasurer
Car Model: '15 Golf R
Membership No: 806
Post by Neuk » Thu Jan 18, 2018 4:24 pm
Where is @BlueBlob, he is an expert at extracting power from an 8v.
Nic
Daily Drive: 2015 VW Golf R
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza » Fri Jan 19, 2018 7:41 am
If money is no issue why not go straight to 16V?
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
AlexTDi
Car Model: '15 Polo GTI
Membership No: 1724
Post by AlexTDi » Fri Jan 19, 2018 7:53 am
You need about 25-30k, give Sarel Eloff from 8v performance a call but you basically need his stage 3 flowed head, high rev kit, bigger valves, Estas 288 or 298cam, his gatsby bottom end (2.1) 11:1 compression so either you run two maps or NF/higher octane fuel daily.
I did all this last year but didn't go 2.1 as I wasn't looking for 110kw and guess what I'm completing this weekend? a 2L 16v ABF build so if you really really really want a strong 8v then do that but a midly tuned 16v will do that power all day every day
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
mike65
Car Model: mk1
Post by mike65 » Fri Jan 19, 2018 9:05 am
16v is in the year plan im buzy getting my parts ready and i only have one car so cant sit without it for long
Watch this space
mike65
Car Model: mk1
Post by mike65 » Fri Jan 19, 2018 9:11 am
AlexTDi wrote:You need about 25-30k, give Sarel Eloff from 8v performance a call but you basically need his stage 3 flowed head, high rev kit, bigger valves, Estas 288 or 298cam, his gatsby bottom end (2.1) 11:1 compression so either you run two maps or NF/higher octane fuel daily.
alot of the above mentioned i can do myself and would like a 90% diy job
the 8v i dont want to spend to much on it because i have to start from scratch with the 16v build,saving most of the cash for the next build...
110kw at the coast for an 8v is easy to get and its enough for a daily...16v im planing on atleast 130kw
Watch this space
AlexTDi
Membership No: 1724
Post by AlexTDi » Fri Jan 19, 2018 9:16 am
Ah you at the coast, yes much simpler then
Alex
Daily:
'15 6C Polo GTI DSG
ICE King
Post by ICE King » Fri Jan 19, 2018 9:23 am
Buy a 2l 8v , use MP9 if existing or go management , branch + exhaust , cam & induction and be happy with it while you build your 16 valve in the background.These mods are doing +-105kw ATF down here in CPT
No point going all out on a 8v when you could have a spend less money getting a stock 16v and making more power.
Unless the plan on only running quarter miles all day then the 8v is good enough, after 400m you'll watch a 16v pass you.
Rides:
Mk1Crazee
Car Model: 1980 Mk1 4 Door 2L8V
Post by Mk1Crazee » Fri Jan 19, 2018 9:24 am
:iagree:
1989 VW Fox 1800 (Sold)
1985 Ford XR3 1600Sport (Restoration Sold)
2004 Mk1 Golf 1.4i Velo Motor (Sold)
1980 Mk1 Old School Golf 2L8V
Shallow Pockets. Backyard Builder :moon:
mike65
Car Model: mk1
Post by mike65 » Fri Jan 19, 2018 9:34 am
@ ice king
I have a 2l agg motor that im doing over very soon my intentions are to bore do full head work branch freeflow and retune
Watch this space
WeirdSteam
Car Model: MK3 Golf GTS
Post by WeirdSteam » Fri Jan 19, 2018 9:40 am
mike65 wrote:@ ice king
Bore to 83.5mm (40 thou oversize) fit a nice 288 cam with flow and branch. And you are sorted.
Sent from my WAS-LX1 using Tapatalk
Car Make: Fiat
Car Model: Uno
Post by Unobeat » Fri Jan 19, 2018 7:24 pm
I soo miss Torker, where has he disappeared to.
He has such epic N/A builds.
supervly
Post by supervly » Sat Jan 20, 2018 11:48 am
Ya where is Torker - he did manage to pull epic power from 8v motors
InquisitiveKid99
Post by InquisitiveKid99 » Sat Jan 20, 2018 12:25 pm
Hey guys, so i have a Polo 9n , ran a whole in the block and took the engine out, i do'nt want to buy the exact same engine i was thinking of buying a 2l 8valve APK .
What I'd like to know is :
1. will it be a straight fit
2. will i need to get another gearbox as well or will the standard 1.4 work
InquisitiveKid99
Post by InquisitiveKid99 » Sat Jan 20, 2018 12:36 pm
hole*
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner » Sun Jan 21, 2018 8:36 am
InquisitiveKid99 wrote:Hey guys, so i have a Polo 9n , ran a whole in the block and took the engine out, i do'nt want to buy the exact same engine i was thinking of buying a 2l 8valve APK .
What is the original motor?
vwpro
Car Make: Audi Quatro, polo Beast and A3
Car Model: S3, Polo Playa,
Post by vwpro » Sun Jan 21, 2018 3:15 pm
You can forget 110wkw on a na 8v motor, not possible with all the money you got. Only to achieve that figures is to do a dyno run on a happy dyno.
Speak to 8v performance, Sarel Ellof if reacable.
https://m.facebook.com/groups/171419086276082
:troll:
dubz-on-drugz
Post by dubz-on-drugz » Sun Jan 21, 2018 11:20 pm
vwpro wrote:You can forget 110wkw on a na 8v motor, not possible with all the money you got. Only to achieve that figures is to do a dyno run on a happy dyno.
I think it's easier to make that power at the coast .many 8v's with itb on pump fuel making more then 110wkw.
