Individual Throttle Bodies
Spelwan88
Registered for: 8 years
Car Model: '90 1.8 Caddy sport
Membership No: 3224
Post by Spelwan88 »
Hi Guys
So I'm doing a little inquiry here today for a future mod. I'm a fan of the feel of the N/A setup so this goes to that.
I'm currently running the following:
HM Block with 83.5mm carravelle pistons
Stock rods
Stock crank
Port + Polished + Gas flowed + swirled vales on std carb and g-cam
50mm wildcat branch + 50mm straight pipe with single freeflow backbox
My questions are:
1. Will it be possible to use my current setup and replace the carb with ITB's
2. If yes than what ITB's should I shop for?
3. Apart from management, dizzy, coil and a fuel pump what other parts are required for this setup to work.
I know the U-Flow setup isn't the best but I may just cut a groove in the rain tray for the trumpets to stick out.
Daily:
04 Audi A4 2.0 (B6)
90 VW Caddy 1.8 Sport
Re: Individual Throttle Bodies
1. Sure
2) something smallish -like 36/38. Maybe even investigate bike setups
3) not that should about cover it.mwhatever is neede to mounnt them and make a throttle cable work.
Spelwan88
Membership No: 3224
Post by Spelwan88 »
Thanks Panic
In your opinion do you think it will make any significant power gains or should I just enjoy the sound of it?
Daily:
04 Audi A4 2.0 (B6)
Will pick up something from a stock carb if sized right. But can't speculate how much as that depends in a huge amount of things that I just don't know right now. Ie. You Don't even have a set of throttles in hand.
Just let me say outright from the start. Toyota job are way too big for your application.
Spelwan88
Membership No: 3224
Post by Spelwan88 »
I was searching for Suzuki GSXR1000 throttles or something in that range. Just thought I'd research it as an alternaitive to just the regular FI conversion.
If its worth a try I'll start sourcing parts over the next couple of months and see what comes of it and you never know. May just be interesting enough to share...
Daily:
04 Audi A4 2.0 (B6)
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
HM block is a 1.6l
The Caravelle pistons will not work as the gudgeon pin hieght is too low for the 77mm crank. To get any piston protrusion you would have to cut the top of the block. Not a good idea as it will weaken the supports for the cylinders situated in the water jackets.
You will have to use Audi 2.2l/ Microbus 2.3l pistons with an 86.4mm (1.8.l) crank to get it all to work without cutting the block.
One tip. Block off the water outlet in the carb head that's in between no.3 and 4 inlet ports.
If you look at bike carbs off the older motors it should work just fine without too many EFI related extra mods.
Spelwan88
Membership No: 3224
Post by Spelwan88 »
missioner wrote:HM block is a 1.6l
Thanks Dude. I actually made a typo error. I have an HV block. Not the HM.
Daily:
04 Audi A4 2.0 (B6)
missioner
Post by missioner »
Much better.
1.9l all the way, for the win.
smitbrandon
Post by smitbrandon »
Really enjoyed the detailed explanation
dubz-on-drugz
Registered for: 11 years 7 months
Post by dubz-on-drugz »
Yes awesome to have guys out there that know what they are doing and can help us .
Nice one missioner!
missioner
Post by missioner »
dubz-on-drugz wrote:Yes awesome to have guys out there that know what they are doing and can help us .
Nice one missioner!ImageImage
Much obliged kind Sir's
