K-Jet swirl pot set up on a ABF running ITB's
Huzi022
Car Model: ABF CADDY [email protected]
Post by Huzi022 » Thu Dec 07, 2017 10:34 am
Hi Guys,
need some guidance,ABF has starvation issues when cornering with under half a tank of Fuel.
i managed to get hold of a K-jet swirl pot set up.
is it worth fitting?
anyone done this before and can offer some guidance?
Currently Running ITB's with one of those mahle filters that has a single feed to the throttles and a return from the filter to the tank.
single pump set up currently with a gravity fed fuel tank.
any advice and help will be much appreciated.
thanks :thumbup:
Re: K-Jet swirl pot set up on a ABF running ITB's
Post by panic-mechanic » Thu Dec 07, 2017 8:32 pm
You not saying what car / which tank etc.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
Huzi022
Post by Huzi022 » Fri Dec 08, 2017 8:20 am
Howzit panic,
its a Caddy standard gravity fed fuel tank.
Post by panic-mechanic » Fri Dec 08, 2017 5:43 pm
caddy tanks are quite good to feed a pump. is your pump right at the outlet? same level?
'09 Audi Q5 3l tdi
PapaJo
Post by PapaJo » Sun Dec 10, 2017 10:15 pm
panic-mechanic wrote:caddy tanks are quite good to feed a pump. is your pump right at the outlet? same level?
:iagree:
Works just fine. There is a ring with a sieve filter inside the tank already and it help to prevent fuel sloshing around a bit. If you can mount pump slightly lower than tank outlet.
One thing to check is the thin breather pipe at the cap end, ensure that it is not blocked to prevent tank airlocks.
Huzi022
Post by Huzi022 » Mon Dec 11, 2017 9:12 am
pump is at the same level, right next to the outlet, no restrictions at all and the filter sits at the front before the throttles.
Huzi022
Post by Huzi022 » Mon Dec 11, 2017 9:18 am
:iagree:
Will check this out.
I read about the sieve and that is can get blocked up so the tank was pulled sieve removed and cleaned out,everything refitted problem still persists.
tried mounting the pump slightly lower to no avail. anything slightly under 50% in the tank and she splutters on hard rights unless completely off the throttle until you no longer cornering.
i even spoke to Sarel about it and he said that its not the first caddy hes come across doing it.
for some reason some do it and others dont :deadhorse:
PapaJo
Post by PapaJo » Mon Dec 11, 2017 11:20 pm
You can get yourself an inline fuel filter (round metal type) or a small resevior of around 500ml in between the tank and pump to act as a swirl pot with fuel in to prevent the surge.
Huzi022
Post by Huzi022 » Tue Dec 12, 2017 8:43 am
PapaJo wrote:You can get yourself an inline fuel filter (round metal type) or a small resevior of around 500ml in between the tank and pump to act as a swirl pot with fuel in to prevent the surge.
thanks bud, will try these out this weekend and feedback.
PapaJo
Post by PapaJo » Mon Jan 29, 2018 4:53 pm
Feedback??
