Mk3 GTS raised lettering placement
- Car Model: Mk5 Golf GTI
Hi. Not sure that this is the right place, but here goes.
I am busy buying a 96 GTS. The previous owner had the car sprayed before I bought it and the panel shop bunched all the raised letters on the right side under the rear light cluster.
Is there a measurement list or layout available somewhere that I can use to place the letters correctly?
I know that "Golf" is on the left and "GTS" on the right, but I need the placement.
I would appreciate any leads or advice.
Thanks in advance.
Thanks in advance.
- Membership No: 2033
Re: Mk3 GTS raised lettering placement
Find a parked one with the correct letter placement, take a ruler and take a pick with ruler to work out placing.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- freezaburn
- Car Make: VW, Audi, Toyota,BMW
- Car Model: GTi,Citi Sport,Raider,A4, 316i
This is for the GTI badge but should hopefully give you an idea. (Download and zoom in)
All Current Rides:
-2009 Audi A4 (B8) 2.0T FSI Avant (155kw)
-2005 Audi A4 (B7) 2.0T FSI Avant (147kw)
-2005 Toyota Hilux D/C 2.7VVTi (118kw)
-1995 BMW E36 316i
-1994 Golf MK3 GTI 2.0 Exec (85kw)
-1986 Citi Golf Sport 1.6 (63kw)
Thanks a million!freezaburn wrote:This is for the GTI badge but should hopefully give you an idea. (Download and zoom in)
Thanks Freezaburn. And the left side where the Golf name is? Is that similar. I thought the vertical lines on the lights somehow line up with the badges but looks like they don't.freezaburn wrote:This is for the GTI badge but should hopefully give you an idea. (Download and zoom in)
- freezaburn
The GOLF logo letter should be smack-bang-in-the middle of the 10mm x 220mm section underneath the light.
Are your letters each separated? I shall have a look and revert to you this evening...
All Current Rides:
-1995 BMW E36 316i
Thanks so far.freezaburn wrote:The GOLF logo letter should be smack-bang-in-the middle of the 10mm x 220mm section underneath the light.
Not sure as I only get the car this week. The panel shop stuck all the letters on the right side under the light cluster!
- freezaburn
Both the OEM logos came as a "single piece", so I suspect that they may have used after market.
All Current Rides:
-1995 BMW E36 316i
Thanks a stack so far. Will let you know how things go once I get my grubby paws on the car! Hopefully by Wednesday!freezaburn wrote:Both the OEM logos came as a "single piece", so I suspect that they may have used after market.
- freezaburn
Here is the other side:
All Current Rides:
-1995 BMW E36 316i
Thanks a million Freezaburn. Am giving it a go this afternoon. Will let you kn9w how it turns out.freezaburn wrote:Here is the other side:
