Adding power steering to mk3 Golf
- Car Model: Mk5 Golf GTI
Was wondering what all is needed to add power steering to a mk3 Golf that was built without it?
From what I understand only from 97 was it standard kit?
Sent from my SM-G925F using Tapatalk
- Pynoxim
Re: Adding power steering to mk3 Golf
The rack, the pump and maybe the column too
Thanks Pynoxim. Would the mounts be there?Pynoxim wrote:The rack, the pump and maybe the column too
- Pynoxim
Everything should mount in just fine, as long as you have all the parts you require. Also for the pump you need the right alternator bracket which has the accomodation for the pump, so any Mk3/Polo 6n bracket
Thanks a million sir!Pynoxim wrote:Everything should mount in just fine, as long as you have all the parts you require. Also for the pump you need the right alternator bracket which has the accomodation for the pump, so any Mk3/Polo 6n bracket
- EX-DOHCTOR
- Membership No: 712
Sell it, and buy a GTi.
Lol. Have not bought it yet! Just kicking tires at this stage.EX-DOHCTOR wrote:Sell it, and buy a GTi.
- EX-DOHCTOR
Don't build what you can buy.
Pynoxim is a polo 6n the one with the large triangular tail lights(sedan model) (a Seat basically)?theunis.visser wrote:Thanks a million sir!Pynoxim wrote:Everything should mount in just fine, as long as you have all the parts you require. Also for the pump you need the right alternator bracket which has the accomodation for the pump, so any Mk3/Polo 6n bracket
Seat cordoba. Yes.
