How to remove lift pump MK2 CSi
175SBU
Car Model: MK1 1.4i, MK2 CSi
Post by 175SBU » Mon Nov 13, 2017 6:34 pm
Car: MKII Fuel Injection CSi
Remove carpet to expose the circular cover.
Remove the 3 screws that secure the circular cover.
Undo the clamps that connects your fuel lines, remove the power connector and undo the moer se groot se union nut(white one)
Remember to clean the dirt around the union nut before removing the sender unit.
Now remove the unit by pulling gently and massaging side to side
The silver part is your lift pump.
Undo the clamp that connects the breather valve and the power connector as well.
The filter and the filter adapter.
New pump.
Comes with new filter
Reassembly is the reverse.
The tricky part is getting this union nut sit proper, just be patient.
