Hi Guys
I am new here, I am going to keep this short and sweet.
I need help with the wiring for the TP100 with the harness, I dnt want to burn the module or anything else .
Three wires , one red, one blue and one green and white that has an eye terminal on it.
Correct me if I am wrong here.
Red will go to the positive of the coil, blue will go the negative and the green&white wire ????
TP 100 Wiring
- Car Model: Jetta 6
- Colonel
- Membership No: 1041
Re: TP 100 Wiring
post a pic of the harness, green& white should be signal
Re: TP 100 Wiring
Thanks UDC .
Will try an upload one shortly...
Re: TP 100 Wiring
Go here. In that diagram is the ignition module. It is a tp100
http://www.dicktator.co.za/Standard%204 ... Layout.pdf
Re: TP 100 Wiring
Hi guys sorry to ask ,,, how do you add the pic in ?
