engine keeps cranking
Dmitriy Olov
Post by Dmitriy Olov »
Hi everyone I have a problem with my polo classic 1999 model 1.6 engine. I just replaced new oil velve Seals, rings and bearings. the online keeps cranking. there is spark and also pulse on injectors but it won't start. it's been going on like this for a month now. when it cranks it feels like It will start but just keep on cranking.
Rubbin&dubbin
Re: engine keeps cranking
Post by Rubbin&dubbin »
try the spare key
[Audi A3 2.0T http://vwclub.co.za/forum/viewtopic.php?f=11&t=177350]
Polo Playa 1.6 Oo oO
Ex: Polo Playa 1.8 - Sold
UDC
Membership No: 1041
Post by UDC »
check timing, check if motor is on TDC before starting
TDIFlava
Registered for: 6 years 7 months
Post by TDIFlava »
think its timing bud sort that out it should start
Audi A3 8p TDI (Decat, twin S4 tail pipes, 17" rims, SQ sound system) (103kw/420nm)
Polo Classic 9n3 1.9 TDI (Decat, SQ sound system)
Golf MK1 aka Gravedigger
Citi Golf 1.4 Sport (RIP)
Make sure you have the fuel supply hose on the right side of the fuel rail. Easy to swop them around.
175SBU
Registered for: 8 years 6 months
Car Model: MK1 1.4i, MK2 CSi
Post by 175SBU »
Will it cause damage if you have them the wrong way around or just builds more pressure?
actually there will be almost no pressure in the rail. No damage to anything. Just swop them around.
dstyler
Car Model: POLO 9N
Post by dstyler »
Good Day Guys need some help
i Have a vw polo 9n 2005 model 1.6i the vehicle has spark at times and then after like 20 some odd minutes it dies on me and refuses to start but will start after 30 minutes i have changed cam shaft position sensor already but the problem still persists can it be the coil ? please assist
When it dies is there no spark? Yes can be the coil but do the basic test to see if it sparks or not when it does not start.
dstyler
Car Model: POLO 9N
Post by dstyler »
When it dies i pulled the no1 plug lead out and put a screw driver in while someone was swinging the car and no spark after i put it back and like waited 20 odd minutes turned the key and she comes to life dont have a clue what could be the problem
dubz-on-drugz
Registered for: 11 years 7 months
Post by dubz-on-drugz »
It's that pickup sensor on the dizzy ,I had that issue on my g3 .. randomly stop sending spark ,check if any other cylinder is getting spark.if u mechanically inclined , remove the dizzy and rotate manually while it's plugged in and see if spark jumps to next lead .
I'm not too sure if this is going to help,but it may help isolate the issue
Uhm yeah there is no dizzy on that car. Uses 60-2 and a cam pickup in combination with a coil pack.
Yes start by swopping the coil out. I have seen 60-2 pickup die when they get hot and come back when cold but that is not really common. At thatbstage if younlook at it with vagcom you will see no rpm reported when you crank the motor.
