Mk1 Golf to TDi?
- Mk1Crazee
- Car Model: 1980 Mk1 4 Door 2L8V
Mk1 Golf to TDi?
Hey guys
found a smashed 2005 Polo 1.9 TDi.
Body is far gone but the motor and other internals are all in order. Just need to get another radiator and intercooler.
No my question is. How hard will it be to convert a Mk1 Golf (Petrol internals) to running the 1.9 TDi setup?
I'm just doing as much research as possible, budget won't be an issue.
Guidance needed from the forum gods
1989 VW Fox 1800 (Sold)
1985 Ford XR3 1600Sport (Restoration Sold)
2004 Mk1 Golf 1.4i Velo Motor (Sold)
1980 Mk1 Old School Golf 2L8V
Shallow Pockets. Backyard Builder
- Membership No: 2033
Re: Mk1 Golf to TDi?
OP's forum name is apt .......
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Mk1Crazee
lol what's that?Howie-WP wrote:OP's forum name is apt .......
aptMk1Crazee wrote:lol what's that?Howie-WP wrote:OP's forum name is apt .......
adjective
1. appropriate or suitable in the circumstances.
HOWIE-WP,
- chucker02
- Car Model: Citi ADY
There is a guy in bloem that has a tdi caddy. I think he also used a polo tdi motor. So strange hearing a caddy that sounds like a polo tdi
1971 VW beetle
1971 VW beetle
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Not any more difficult than putting a 1.8T with oem management into a Mk1, if you have a whole car as a donor. You will need to swap over the motor, gearbox, engine loom, pedal, all engine related sensors and cluster and have the immobiliser defeated on the ecu. You will also need the pump, not sure how the tank works with the PD motors. Additionally you will have to ground out or code out the various warning lights on the cluster like ABS/Airbags etc. It will be a great conversion though if you're willing to spend the time organising the wiring.
- Carel040
I think it's great idea would also like to take on a project like that but so space
- Carel040
Mk one crazee what is the car going for
I saw a video of the caddy Chucker was talking about. That thing was maaaaad.
It can be done, true
Can you do it? Well that depends. How good is your welding and fabrication skill? Can you do car wiring?
Lastly decide how much time you are prepared to invest into the project. The aforementioned Caddy, the builder was expert welder and a mechanic by profession and it still took him more than 10 months to complete.
- Mk1Crazee
Seems the wiring is the most time consuming, none of the engine mountings are damaged so i guess i could just weld those on to the golf.THANAS wrote:Not any more difficult than putting a 1.8T with oem management into a Mk1, if you have a whole car as a donor. You will need to swap over the motor, gearbox, engine loom, pedal, all engine related sensors and cluster and have the immobiliser defeated on the ecu. You will also need the pump, not sure how the tank works with the PD motors. Additionally you will have to ground out or code out the various warning lights on the cluster like ABS/Airbags etc. It will be a great conversion though if you're willing to spend the time organising the wiring.
I have experience wiring Fi cars just never did a Tdi before, hoping its similar.
Picked the polo up for R22k
Motor seems healthy though.
Anything else i need to know?
Will keep you guys posted, thanks for the responses
It is an awesome conversion if you have the patience tomsee it through. You have to move the fuel,cooler too if there is one on that car.
- Mk1Crazee
I was thinking that. Would it be a good idea to cool the fuel on the return to tank?panic-mechanic wrote:It is an awesome conversion if you have the patience tomsee it through. You have to move the fuel,cooler too if there is one on that car.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Should be an interesting build project, start a ride thread of the project.
I remember some time ago, coming across a bettle with a 1.9tdi motor and it sounded good.
- Criminal Troll.
engine mounts are the same used as in a 1.8T swap.
5 speed gearbox will make life easy.
will be awesome. killing to do one
- Neuk
- Treasurer
- Membership No: 806
- Mk1Crazee
I'll start a thread once i've got everything.Unobeat wrote:Should be an interesting build project, start a ride thread of the project.
Been thinking about this for a while.
- amstel18
- Car Model: Tiguan Allspace
nice looking citi.
However theres only one pic of the engine bay which is useless
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
It wasn't a build thread or about the engine at all. It really was about the okes body work. He has a body shop...
- Neuk
- Treasurer
It perfectly answers whether a modern TDi conversion in to a Mk1 shell can be done as well as the standard that can be achieved.amstel18 wrote:nice looking citi.
- THANAS
- Forum Advertiser
There is a guide for the conversion online, I used a great guide put together by 'rubjohnny' that detailed the splicing of wires from the ecu and loom into both the CE1 and CE2 fuseboxes. There is a similar guide for the tdi if photorekit hasn't killed it.
- Tman21
- Car Model: BosPolo
- Membership No: 3247
Just imagine the #hastagsTHANAS
#VelocitySleeperSooter. . . .
#TMAN21
#TMAN21
- Mk1Crazee
been looking all over, no detailed threads though. many guys from Europe done itTHANAS wrote:There is a guide for the conversion online, I used a great guide put together by 'rubjohnny' that detailed the splicing of wires from the ecu and loom into both the CE1 and CE2 fuseboxes. There is a similar guide for the tdi if photorekit hasn't killed it.
- Mk1Crazee
So guys, whats the difference between the 1.9TDi BXE and ASZ? I know this polo comes with the ASZ which seems to be common
- Neuk
- Treasurer
BXE - 77kwMk1Crazee wrote:So guys, whats the difference between the 1.9TDi BXE and ASZ? I know this polo comes with the ASZ which seems to be common
ASZ - 96kw
- Carel040
And the ATD lump aswell smaller turbo injectors and 5 speed box
