Morning Guys
I am restoring a 1984 Golf mk1 1300. I replaced the carb with a gold wagen carb, the car drives nice but the car keeps stalling when i stop at robot. And also i only get about 10km per litre, is this normal
hope someone can help me
regards
Stalling due to new carb
- Car Make: Golf
- Car Model: Mk1
- Wolf Mk2 16V
Re: Stalling due to new carb
Yip 10k's a litre is standard fare for a 1.3 carb - i have owned quite a few.... my 1800 sport gives 11-12 and chico 1.3 exactly that (low mile well set up car!)
Those chinese carbs are pesky...where are you based?
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
Didnyou connect the fuel cutoff solenoid to power and made sure the earth wire from the carb is connected to the head.
- Car Make: Golf
- Car Model: Mk1
the cut off is connected to power and the earth is also connected, however i took off my dizzy cap and it looks like 1 and 4 is burning on the contact points and also looks like something is cutting the cap on inside. what is causing this.
Incorrect rotor
- Car Make: Golf
- Car Model: Mk1
thanx. so what can i do about the stalling issue.
What rpm does it idle at. Have you tried to raise it a little. Is the idle mixture set correct. So hard to just guess with the absolute no detail you have given.
