Mk2 2.0 8v agg spitronics cold start
Hi all. I've had my car tuned a month ago and I have cold start problems and over fueling wen the car is cold but dissappear when the car is on operating temp. Motor has 282 estas cam and 57ml powerflow exhaust. Any advice would be appreciated. TIA
Sent from my G3221 using Tapatalk
- Zeyad
- Car Model: Velociti
Re: Mk2 2.0 8v agg spitronics cold start
First and easiest thing to do is replace your temperature sender unit, it is about R120 at the spares shop. I had a similar problem on my previous velo mp9 system.. After replacing the temp sender the problem went away.
Sent from my WAS-LX1 using Tapatalk
Current: 2010 Bmw 320i (A) ///M-Sport Dynamic Pack
Carbon fibre splitters+mirrors+rear spoiler,
18" M-sport wheels (Anthracite)
Leather seats with blue stitching
Sunroof
Rear PDC
Ex Ride: 2005 VeloCiti 1.6i
52mm Piper exhaust + branch
K&N flatpad filter plus CAI
60mm Razor lowering springs
Gas Ryder shortened shocks
Sunroof
Rear PDC
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
zlakay001 wrote:Hi all. I've had my car tuned a month ago and I have cold start problems and over fueling wen the car is cold but dissappear when the car is on operating temp. Motor has 282 estas cam and 57ml powerflow exhaust. Any advice would be appreciated. TIA
After the car was tuned, did you not have any issues with Cold start?
When winter kicked in, i had to add more petrol % on the Water temp Correction section of my map and yes i had a Temp sensor died on me.
The symptoms of a failed temp sensor were there even when the car was on operating temp, cold start was an issue too.
take it back to the tuner and let him fix it.
panic-mechanic wrote:take it back to the tuner and let him fix it.
Cold start and temperature compensation on map is not set correct and needs to be trimmed.
Where are you based?
- Unobeat
Yep
Take it back to the tuner and get him to sort it out for you.
I know that with cold starting the car will need to sleep over night so that the tuner can test the cold start when the motor is cold.
Sent from my SM-A500F using Tapatalk
Somehow the cold start was set. He told me it's the camshaft that makes that the car won't idle when it's cold. I am based in cpt
- Donavan
zlakay001 wrote:Somehow the cold start was set. He told me it's the camshaft that makes that the car won't idle when it's cold. I am based in cpt
I suggest getting a new tuner......this guy is clearly avoiding the obvious issue.
Audi A4 B8 2.0T - Daily
Donavan wrote:zlakay001 wrote:Somehow the cold start was set. He told me it's the camshaft that makes that the car won't idle when it's cold. I am based in cpt
I replaced the temp sender and changed my plugs. Problem solved thanx
I still don't get this. It was somehow set, but temp sensor faulty and replaced sensor and plugs and now idle without issues. How could the tuner set this then as he said the camshaft don't let it idle when cold?zlakay001 wrote:Somehow the cold start was set. He told me it's the camshaft that makes that the car won't idle when it's cold. I am based in cpt
Anyhow, glad it is sorted now.
