276 cam + vernier pulley
Spoiltbrat
Post by Spoiltbrat » Sun Sep 17, 2017 11:01 am
I have a 2002 polo classic 1.6 and would like to know if its advisable to put a 276 cam + vernier pulley, also updating the ecu to a 1.8. Will this give it more power, and will it work well
Car is being used as a everyday runner
WeirdSteam
Car Model: MK3 Golf GTS
Re: 276 cam + vernier pulley
Post by WeirdSteam » Sun Sep 17, 2017 11:52 am
You don't need a vernier pulley unless you Deck the Block or Skim the head.
The 1.8 ecu will do nothing for power on your engine, the cam will increase power but you will need after-market Management to be tuned to get the most out of your Cam.
Your Current MP9 ecu will run with the 276 cam but it will not make allot more power
Spoiltbrat
Post by Spoiltbrat » Sun Sep 17, 2017 12:13 pm
What else can i do to increase power, without blowing the bank
WeirdSteam
Post by WeirdSteam » Sun Sep 17, 2017 12:26 pm
Increase CR, Cam, port & flow head. Branch and decent exhaust. And Management. To make power on a N/A motor takes money and allot of it.
WeirdSteam
Post by WeirdSteam » Sun Sep 17, 2017 12:27 pm
I recently built a 2.0 shorblock Running a 288 estas. I have spent 12k on just the motor and engineering and have not done management yet that is another 5K plus.
chucker02
Car Model: Citi ADY
Post by chucker02 » Sun Sep 17, 2017 12:38 pm
The 276 cam should give you a good increase. You can either fit a unichip or go full Aftermarket management which is a better option as it is alot more tuneable. I personally dont understand why people still fit unichips to their cars. A cam, branch and decent AFM will give you a good increase
2003 Audi A3 1.8t
2007 Citi golf. ADY with Spitronics 60-2, Brospeed 4-2-1 branch, Poly mounts and coilies. CCBB Limited edition
Rides Thread: http://vwclub.co.za/forum/viewtopic.php?f=11&t=183329
2002 Citi golf. ADY engine with GW carb, Viper 4-2-1 branch, 282 estas cam, 57mm freeflow, GW delarey big brake kit and GW delarey gearbox mounting.
1971 VW beetle, my first love
Carel040
Post by Carel040 » Sun Sep 17, 2017 4:25 pm
Yes I agree in that case I will rather buy a diesel mutch more bang for the buck
Car Model: POLO 6N
Post by [email protected] » Sun Sep 17, 2017 9:34 pm
chucker02 wrote:The 276 cam should give you a good increase. You can either fit a unichip or go full Aftermarket management which is a better option as it is alot more tuneable. I personally dont understand why people still fit unichips to their cars. A cam, branch and decent AFM will give you a good increase
There's nothing wrong with dastek unichips, the drivability is way better with them.
I have it on my car with a 288 cam and use it daily, I get around 500km on the tank ( in town driving) and the car is so smooth that you would think it has a 272 cam.
1998 Polo classic 6n
2.0L-bmc filter,branch and zorst
2008 caddy panel van
1.6l petrol,bone stock
chucker02
Car Model: Citi ADY
Post by chucker02 » Sun Sep 17, 2017 10:12 pm
Ok
2003 Audi A3 1.8t
Post by panic-mechanic » Mon Sep 18, 2017 6:17 am
As with anything it is very much tuner related. Some guys will go tot the trouble and have the knowledge to do it properly and some will just tape it in place and charge you.
Really. Not lying. I once found a unichip loosely taped in place, none of the actual wires connected and the owner showing me a dyno graph they gave him but he said the car did not feel any better.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
HenkSnyman
Wheel Whore
Post by HenkSnyman » Tue Oct 17, 2017 11:16 am
On my polo 1.9 TDI the Dastek chip made huge improvements in performance and fuel consumption
