Mk 1 1.6i fuel pump
Re: Mk 1 1.6i fuel pump
You can buy the sebring one for even less at ace motor parts in springs.
The cheap goldwagen one is chinese and it is luck of the draw. You can buy one and it will last as a very expansive bosch or you get one and it lasts 2 weeks and give it up.
Do you feel lucky , punk (delivered in dirty harry gruff voice)
Exactly the same thing. Some die some don't. But i have had some bosch pumps also keel over and die early on. So literally pays your money and takes your chances.
The sebrings seems ok for the price.
Their website is short and sweet. Not even sure where it's made or if it is local or what. Ok edit the workers in the pics are clearly oriental but who knows.
http://sebringelectronics.com/
Which year? Mpi?
Okmthat should still be mp9. Get the timing set correctly and check if the diagnostic in reading blocks show the correct values for water temp and manifold pressure.
No then I give up.
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Post by THANAS »
The port must be there somewhere unless your car was converted to Mp9 without including the port.
On the old dash they were under the ashtray in the centre console. It literally was a loose port lying around, you had to scratch there to find it
