Clearance around the lifters
raveen21
Registered for: 6 years 8 months
Post by raveen21 »
Hello to all. Going to put a 288 or 298 cam soon.
Just wanted to know if the head area around the lifters can be cleared without removing the head.
WeirdSteam
Car Model: A3 Sportback 1.8 TFSI
Re: Clearance around the lifters
Post by WeirdSteam »
Yes can be done without removing the head but you have to make sure that you get ALL the metal shavings out as you go otherwise it ends up in your oil and bearings.
Did mine recently for the 288 estasImageImage
Yes pencil grinder and a lot of patience. As mentioned you need to get all the shavings
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn »
288 is a straight fit, well an estas 288
WeirdSteam
8VALVE-zn wrote:288 is a straight fit, well an estas 288
Nope not on all heads
I have a Estas 288 that iIbought from Panic and the head needed to be clearance d , i have an 2.0 ADY Head 5 Cam caps (Hydro)
Yup some heads need to be clearanced some not.
