Black smoke when revving my citi golf
Fagrodeen
Postby Fagrodeen » Tue Sep 12, 2017 6:32 pm
Hi guys, I own a 2009 city golf 1.4i. I have a mileage of 172 000 km on the car. I experienced high fuel consumption recently after I had the car serviced. I replaced the Map sensor and the coolant temperature sensor with OEM parts by VW. If I rev the car black smoke exhausts by tail pipe. If I drive say 160 km/h no smoke even then appears only when I rev the car. Diagnostics do not find any faults. What can I do?
keval
Car Model: 1.9TDI SL /6R GTI
Re: Black smoke when revving my citi golf
Postby keval » Wed Sep 13, 2017 8:55 am
Sure u didnt fill diesel?....just joking, check airflow sensors
Current : Sportline,63mmD.P, 57mm zorst, Eibach springs, Custom Intake, Toxic Tuned
2014 6R GTI
http://www.vwclub.co.za/forum/viewtopic.php?f=11&t=179665&p=2195166#p21951
Polo 1.6 6R comfortline
http://vwclub.co.za/forum/viewtopic.php?f=11&t=165585&p=1943642#p1943642
http://www.vwclub.co.za/phpbb3/viewtopic.php?f=11&t=155544&start=25
Polo 1.9TDI SL
bmw E90 320I Msport
bmw E36 328i Msport
Postby Kyle » Wed Sep 13, 2017 9:32 am
Don't rev it then
Neuk
Treasurer
Treasurer
Car Model: '15 Golf R
Membership No: 806
Postby Neuk » Wed Sep 13, 2017 9:34 am
Kyle wrote:Don't rev it then
Or drive at 160km/h everywhere.
Nic
Daily Drive: 2015 VW Golf R
ALRoN73
Postby ALRoN73 » Wed Sep 13, 2017 4:37 pm
Both great ideas :thumbup:
dubz-on-drugz
Postby dubz-on-drugz » Wed Sep 13, 2017 9:10 pm
Is that not signs of over fueling ?
Postby panic-mechanic » Thu Sep 14, 2017 7:58 am
It does not have an airflow sensor.
Oh look, another failed mpi.....same thing in comon. 2009.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
TDIFlava
Postby TDIFlava » Thu Sep 14, 2017 8:09 am
Why did you replace the map sensor was it faulty? try to refit the old one maybe see if it works
Audi A3 8p TDI (Decat, twin S4 tail pipes, 17" rims, SQ sound system) (103kw/420nm)
Polo Classic 9n3 1.9 TDI (Decat, SQ sound system)
Golf MK1 aka Gravedigger
Citi Golf 1.4 Sport (RIP)
Postby panic-mechanic » Thu Sep 14, 2017 8:42 am
Becuase that is how a lot of people recommend you do daignosis. Change everything that you think ot could be and hope it solves the problem.
'07 Audi A4 2l TDI
TDIFlava
Postby TDIFlava » Thu Sep 14, 2017 9:03 am
You right Panic part changers, like panel beaters thees days change the panel not repair
Postby Kyle » Thu Sep 14, 2017 9:05 am
panic-mechanic wrote:Becuase that is how a lot of people recommend you do daignosis. Change everything that you think ot could be and hope it solves the problem.
90% of "Mechanics" in SA
smashedmink
Technical Advisor
Technical Advisor
Car Model: VW Fox
Membership No: 1929
Postby smashedmink » Thu Sep 14, 2017 11:07 am
Is the coolant temperature sensor not a common problem causing over fueling ?
Current: 1991 VW Fox 1600L
Ex: 2003 Mk4 Golf GTi
132hp/98.5kw & 204nm atw @ Oettinger Edenvale
Ex: 1998 Mk3 Jetta CLi 2.0
116.6hp/87kw & 179nm atw @ Stealth (Coastal + NF 5ron)
Postby panic-mechanic » Thu Sep 14, 2017 11:27 am
Only if it is faulty. :wink:
Which you can check bu loking at the temparature reading block in vcds. It will differ from what the engine actually is.
How do you know how hot the engine actually is.
Well before you start it in the day it will be basically ambient. If you don't know what ambient is open the weather app on your phone, it will be damn close to that.
Then If th engine had been running wait for the fans to come on. That is between 95 and 98 on most cars. If the water temp is displaying 10 degrees you know it's broken......
Simple case of using tools , some deduction, some logic and some intelligence.
Combined it is called common sense.
'07 Audi A4 2l TDI
smashedmink
Technical Advisor
Technical Advisor
Car Model: VW Fox
Membership No: 1929
Postby smashedmink » Thu Sep 14, 2017 1:27 pm
panic-mechanic wrote:Only if it is faulty. :wink:
Makes perfect sense :hug:
Return to “N/A Engines”
Users browsing this forum: thepot and 19 guests
