Eratic 16v
Eratic 16v
hey guys im new to the forum thing so please forgive me if im not technical enough ,,i have a 1980 golf one 2 door which i have been building for the last 5 years . the motor was swaped out for a 1.8 16v kr motor and am running gotech management .frustration is starting to set in first off idling is erratic ,and fuel consumption is horenduss around 15 to 18 l/to a 100km ,,also developed and oil leak I hate oil leaks so any help would be greatly appreatiated
Re: Eratic 16v
Fix the oil leak and get the management tuned properly by someone who knows what they are doing.
- Car Model: MK3 Jetta 1.8 CSX, 1976 Beetle
Re: Eratic 16v
Can you see where the oil leak is coming from?
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Re: Eratic 16v
Hoping it is a gasket or seal leaking.kylebassani wrote:Can you see where the oil leak is coming from?
Agree with others, get it properly tuned. Confirm your injector wiring and trigger pulse setup to injectors from ecu as it could be triggering all 4 injectors on each trigger event.
Re: Eratic 16v
thanks people oil leak is from the distributor and the cam seal ,,have taken the car to 3 different tuners not winning all they want is money everytime to put it on the dyno with no interest in getting the car sorted ,so yeah not happy ,i have double checked it is wired for sequential and is working correct
Re: Eratic 16v
What area are you in?
Re: Eratic 16v
Buy the dissy seal from VW dealer as they don't last from anywhere else.
- Car Model: 18 Polo Vivo
- Membership No: 1691
Re: Eratic 16v
is it a oem dizzy or a aftermarket one.
I may have a dizzy seal found it the other day
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
Re: Eratic 16v
robertsham JHB SouthJetta2 wrote:What area are you in?
Re: Eratic 16v
thanks panic machanic like the name will check with Dornat tommorowpanic-mechanic wrote:Buy the dissy seal from VW dealer as they don't last from anywhere else.
Re: Eratic 16v
aftermarket one still have the original but it needs overalling ,,,thanks for the offernd_s wrote:is it a oem dizzy or a aftermarket one.
Re: Eratic 16v
Get the oil leaks sorted and then find someone that can tune the gotech system for you.freakincoolhatch wrote:thanks people oil leak is from the distributor and the cam seal ,,have taken the car to 3 different tuners not winning all they want is money everytime to put it on the dyno with no interest in getting the car sorted ,so yeah not happy ,i have double checked it is wired for sequential and is working correct
RBTS would be able to sort this for you.
http://www.rbtsracing.co.za/
Re: Eratic 16v
Good luck fixing the aftermarket dizzy..
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
Re: Eratic 16v
Any Update?
