Noisy Hydraulic Lifters - VW 8 valve
Spelwan88
Car Model: '90 1.8 Caddy sport
Membership No: 3224
Post by Spelwan88 » Mon Sep 11, 2017 9:03 am
Hi guys,
I have a 1990 VW Caddy 1.8 (HV). I had an oil leak from the rear main seal so I replaced all seals and gaskets with Victor Reinz Kit as well as I had the cylinder head reconditioned with the valves and valve guides and it was skimmed. Since reassembling the engine I went from using Shell Helix HX5 High Mileage (25W - 40) oil to Shell Helix HX5 (15W - 40) and what I am experiencing now is a ticking noise from the cylinder head on acceleration and it gets louder with at higher rpm's, but it goes away (or slightly quieter) when I'm off throttle . Self-diagnosis tells me is that its bad hydraulic lifters.
If I am correct, I got quotes from GW and Alert. Which would be the better purchase?
GW
INA - R 78 each - R 624 (Kit)
Meyle - R 90 each - R 720 (kit)
Alert
Jap Tech - R 40 each - R 320 (kit)
Re: Noisy Hydraulic Lifters - VW 8 valve
Post by panic-mechanic » Mon Sep 11, 2017 9:18 am
Ina make. Period. That's all.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Spelwan88
Membership No: 3224
Post by Spelwan88 » Mon Sep 11, 2017 9:23 am
Thanks Panic! :thumbup:
VAG Fan
Post by VAG Fan » Mon Sep 11, 2017 9:56 am
While I agree with choosing INA as a brand >>if<< the lifters need replacement, I disagree with the diagnosis. Lifter noise is not dependent on engine load. (I mean, just think about it for a moment.)
I would bet that you have a slight leak on the exhaust manifold.
Spelwan88
Membership No: 3224
Post by Spelwan88 » Mon Sep 11, 2017 10:03 am
In that case I should probably have that looked at first before I go out and by lifters.
kylebassani
Car Model: MK3 Jetta 1.8 CSX, 1976 Beetle
Post by kylebassani » Mon Sep 11, 2017 10:33 am
I do agree with VAG Fan, sounds like it could be a pinging noise you are hearing. That is just my 2c.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Wolf Mk2 16V
Post by Wolf Mk2 16V » Mon Sep 11, 2017 11:50 am
kylebassani wrote:I do agree with VAG Fan, sounds like it could be a pinging noise you are hearing. That is just my 2c.
yeah... you did have the head skimmed.... not sure but I've heard that you can get a thicker head gasket to stop pinging on these engines?
2015 VW Golf Gti Oettinger (okay okay software only!)
1990 Golf GTi 16 Valve Executive (KR Baby!)
1993 Citi Golf Designa 1800
2015 VW Move Up!
2014 VW Transporter T5 Single Cab Long Wheel base
2013 VW Transporter T5 Single Cab Long Wheel base
2002 VW Citi Golf Chico 1.3 -sold :(
PapaJo
Post by PapaJo » Tue Sep 12, 2017 12:00 am
Post a video of the motor at idle. That way we can listen to the noise and direct you where the noise is coming from.
One other thing to check depending how much was skimmed off from the head, check where the exhaust manifold bottom holes are and if you use the smooth metal exhaust gaskets that they are not catching on the block or head gasket preventing from a good seal on the head and leaking there.
Spelwan88
Membership No: 3224
Post by Spelwan88 » Tue Sep 12, 2017 8:30 am
PapaJo wrote:Post a video of the motor at idle. That way we can listen to the noise and direct you where the noise is coming from.
I will do that ASAP. I am using the metal gaskets but I did check if they were catching and it seemed to have cleared but I also have the semi-metal gaskets that came with the gasket kit, perhaps they might seal better.
Spelwan88
Membership No: 3224
Post by Spelwan88 » Thu Sep 14, 2017 1:59 pm
So just an update. I tried to record a video but the sound was kak but it turned out that the branch was not locked tight enough.
Thanks for the help guys, really appreciate it
kylebassani
Post by kylebassani » Thu Sep 14, 2017 9:14 pm
Spelwan88 wrote:So just an update. I tried to record a video but the sound was kak but it turned out that the branch was not locked tight enough.
Good to know you found the problem
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
PapaJo
Post by PapaJo » Fri Sep 15, 2017 12:57 am
Great stuff!!
Was this on the studs holding / fastening the branch on to the head?
Spelwan88
Membership No: 3224
Post by Spelwan88 » Fri Sep 15, 2017 8:28 am
Yeah it was, turns out that my mate didn't put the spring washers on, neither did he turn the bolts more than just hand tight :crazy:
PapaJo
Post by PapaJo » Fri Sep 15, 2017 8:58 pm
Spelwan88 wrote:Yeah it was, turns out that my mate didn't put the spring washers on, neither did he turn the bolts more than just hand tight :crazy:
Facepalm your friend :lol:
