2L 8v short vs long intake
Hello to all.
Just need someone to clear this up for me.
I was told that that the long intake make more torque than the short intake.
Is this true?
Is this true?
- chucker02
- Car Model: Citi ADY
Re: 2L 8v short vs long intake
Yes
1971 VW beetle
1971 VW beetle
- dubz-on-drugz
Just remember the short intake makes more hp
- Car Make: ShitiGolf + CRX
Which is Which?
You don't really specify which intakes we are talking about there.
Factory 2E or factory simos or mp9 or some home made job or what short vs long manifold exactly.
- dubz-on-drugz
@panic , I'm not sure if this is the same question, it's a conversation I always come across, longer intake plenum from the 2e makes more torque then the shorter intake plenum setup (both are vw made ) , the shorter Intake plenum is told to make more HP.
There are 3 different manifolds. be specific. And then there are several versions of mp9 on top of that.
So no simple short vs. long. And it will differ for different builds on top of that. People that give you a generic answer actually is talking about 5th hand info or regurgitating some stuff they heard.
Unless you can tell me which manifold you refer to specifically there is no simple cut and dried this one is better than that one answer. And then for your specific build you will have to try them to know for sure.
Sorry panic .i have the agg import engine
I have the agg original short intake and was comparing it to the 2E long intake
- WeirdSteam
- Car Model: A3 Sportback 1.8 TFSI
The MP9 also has a long intake.
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Short intake of the ADY/AGG vs 2E Long intake/MP9 Long intake - I will choose the long intake all day everyday, either of them.
the 'right' mp 9 one will make better torque and hp all day long.
- dubz-on-drugz
@panic, what do you mean by right , does this mean a modified intake ,or a specific engine intake
There are at lewst 3 versions of mp9 maifolds. One of which is better than the other.
- Zeyad
- Car Model: Velociti
Hi Panic.. How do u tell the difference between the 3?panic-mechanic wrote:There are at lewst 3 versions of mp9 maifolds. One of which is better than the other.
Sent from my WAS-LX1 using Tapatalk
Current: 2010 Bmw 320i (A) ///M-Sport Dynamic Pack
Carbon fibre splitters+mirrors+rear spoiler,
18" M-sport wheels (Anthracite)
Leather seats with blue stitching
Sunroof
Rear PDC
Ex Ride: 2005 VeloCiti 1.6i
52mm Piper exhaust + branch
K&N flatpad filter plus CAI
60mm Razor lowering springs
Gas Ryder shortened shocks
Sunroof
Rear PDC
They look different and the one makes more power.
- Zeyad
Hmm ok thanks il see if i can find a pic of mine and send it throughpanic-mechanic wrote:They look different and the one makes more power.
Sunroof
Rear PDC
Sunroof
Rear PDC
- WeirdSteam
My Mp9 has the VW Logo on top. I have seen abother mp9 with no Logo as well
- chucker02
Polo playa came with the one with the vw logo. All the FI golfies I have seen came with the same mp9 intake with no logo
1971 VW beetle
1971 VW beetle
- Car Model: VW Caddy 2K 2.0 8v
Yep, it's the polo mp9 intake that makes the best power.
2008 VW caddy panel van 2.0 8v
2012 Nissan Pathfinder 2.5 Dci Le
The one with the VW stamp up front is the best to use...My long intake out a Velo has a bit of work on it, I doubt there will be any more power for me to pull out even with that intake.
Hi guys I am new here and I saw ur topic about short and long intake I have s 2litre 8valve ady motor and that comes standard with short intake and the revs pick up much faster
