2L 8v short vs long intake
raveen21
Post by raveen21 » Fri Sep 08, 2017 10:19 pm
Hello to all.
Just need someone to clear this up for me.
I was told that that the long intake make more torque than the short intake.
Is this true?
chucker02
Car Model: Citi ADY
Re: 2L 8v short vs long intake
Post by chucker02 » Fri Sep 08, 2017 10:54 pm
Yes
2003 Audi A3 1.8t
2007 Citi golf. ADY with Spitronics 60-2, Brospeed 4-2-1 branch, Poly mounts and coilies. CCBB Limited edition
Rides Thread: http://vwclub.co.za/forum/viewtopic.php?f=11&t=183329
2002 Citi golf. ADY engine with GW carb, Viper 4-2-1 branch, 282 estas cam, 57mm freeflow, GW delarey big brake kit and GW delarey gearbox mounting.
1971 VW beetle, my first love
dubz-on-drugz
Post by dubz-on-drugz » Sun Sep 10, 2017 8:57 pm
Just remember the short intake makes more hp
-=sT3V3=-
Car Make: ShitiGolf + CRX
Car Model: 92' ADY + 91' B20Vtec
Post by -=sT3V3=- » Mon Sep 11, 2017 7:20 am
Which is Which?
Post by panic-mechanic » Mon Sep 11, 2017 8:10 am
You don't really specify which intakes we are talking about there.
Factory 2E or factory simos or mp9 or some home made job or what short vs long manifold exactly.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
dubz-on-drugz
Post by dubz-on-drugz » Mon Sep 11, 2017 9:48 am
@panic , I'm not sure if this is the same question, it's a conversation I always come across, longer intake plenum from the 2e makes more torque then the shorter intake plenum setup (both are vw made ) , the shorter Intake plenum is told to make more HP.
Post by panic-mechanic » Mon Sep 11, 2017 10:11 am
There are 3 different manifolds. be specific. And then there are several versions of mp9 on top of that.
So no simple short vs. long. And it will differ for different builds on top of that. People that give you a generic answer actually is talking about 5th hand info or regurgitating some stuff they heard.
Unless you can tell me which manifold you refer to specifically there is no simple cut and dried this one is better than that one answer. And then for your specific build you will have to try them to know for sure.
'09 Audi Q5 3l tdi
raveen21
Post by raveen21 » Mon Sep 11, 2017 12:33 pm
Sorry panic .i have the agg import engine
raveen21
Post by raveen21 » Mon Sep 11, 2017 12:36 pm
I have the agg original short intake and was comparing it to the 2E long intake
WeirdSteam
Car Model: MK3 Golf GTS
Post by WeirdSteam » Mon Sep 11, 2017 12:46 pm
The MP9 also has a long intake.
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn » Mon Sep 11, 2017 3:59 pm
Short intake of the ADY/AGG vs 2E Long intake/MP9 Long intake - I will choose the long intake all day everyday, either of them.
2000 Golf 1 Chico- CRANKCASE [Std bottom end, head gas flowed,ported & chopped by Fastcar, 288 Estas Billet, 4-2-1 43mm Brospeed Branch, 50mm-57mm-63mm Exhaust] + THE PART (2B1 speacials) -Final power @ Autotrix 111wkw & 210wnm :drool:
2011 Jetta 5 1.6 TDI DSG - CRANKCASE Tow Services [CPI Stage 1 with DPF Delete]
Post by panic-mechanic » Mon Sep 11, 2017 8:20 pm
the 'right' mp 9 one will make better torque and hp all day long.
'09 Audi Q5 3l tdi
dubz-on-drugz
Post by dubz-on-drugz » Mon Sep 11, 2017 9:11 pm
@panic, what do you mean by right , does this mean a modified intake ,or a specific engine intake
Post by panic-mechanic » Tue Sep 12, 2017 10:48 am
There are at lewst 3 versions of mp9 maifolds. One of which is better than the other.
'09 Audi Q5 3l tdi
Zeyad
Car Model: Velociti
Post by Zeyad » Wed Sep 13, 2017 10:02 pm
panic-mechanic wrote:There are at lewst 3 versions of mp9 maifolds. One of which is better than the other.
Hi Panic.. How do u tell the difference between the 3?
Current: 2010 Bmw 320i (A) ///M-Sport Dynamic Pack
Carbon fibre splitters+mirrors+rear spoiler,
18" M-sport wheels (Anthracite)
Leather seats with blue stitching
Sunroof
Rear PDC
Ex Ride: 2005 VeloCiti 1.6i
52mm Piper exhaust + branch
K&N flatpad filter plus CAI
60mm Razor lowering springs
Gas Ryder shortened shocks
Post by panic-mechanic » Thu Sep 14, 2017 8:36 am
They look different :wink: and the one makes more power.
'09 Audi Q5 3l tdi
Zeyad
Car Model: Velociti
Post by Zeyad » Thu Sep 14, 2017 9:01 am
panic-mechanic wrote:They look different :wink: and the one makes more power.
Hmm ok thanks il see if i can find a pic of mine and send it through
Sunroof
Rear PDC
WeirdSteam
Post by WeirdSteam » Thu Sep 14, 2017 9:15 am
My Mp9 has the VW Logo on top. I have seen abother mp9 with no Logo as well
chucker02
Car Model: Citi ADY
Post by chucker02 » Thu Sep 14, 2017 9:34 am
Polo playa came with the one with the vw logo. All the FI golfies I have seen came with the same mp9 intake with no logo
2003 Audi A3 1.8t
Car Model: POLO 6N
Post by [email protected] » Fri Sep 15, 2017 9:11 am
Yep, it's the polo mp9 intake that makes the best power.
1998 Polo classic 6n
2.0L-bmc filter,branch and zorst
2008 caddy panel van
1.6l petrol,bone stock
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn » Fri Sep 15, 2017 1:21 pm
The one with the VW stamp up front is the best to use...My long intake out a Velo has a bit of work on it, I doubt there will be any more power for me to pull out even with that intake.
Wheatie
Post by Wheatie » Fri Sep 15, 2017 9:47 pm
Hi guys I am new here and I saw ur topic about short and long intake I have s 2litre 8valve ady motor and that comes standard with short intake and the revs pick up much faster
