2.0 8v turbo conversion
JakesVW
Car Model: Citi 2.0 8v
Post by JakesVW » Wed Sep 06, 2017 5:50 pm
I've done a 2.0 8v with sidies conversion on my citi golf and would like to know if i would be able to do a turbo conversion on it. What price range can i prepare for (stock 2.0 motor at the moment) and what would i need to change?
Thanks in advance
Re: 2.0 8v turbo conversion
Post by panic-mechanic » Wed Sep 06, 2017 7:27 pm
what is your budget.
Are you asking if you can use the sidedraughts?
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
JakesVW
Post by JakesVW » Wed Sep 06, 2017 10:12 pm
panic-mechanic wrote:what is your budget.
I want to know about how much it will be if i want to do a conversion and what needs to be done to the motor,, sidedrafts or MP9, but preferably with sidies...
Post by panic-mechanic » Thu Sep 07, 2017 7:44 am
you cannot blow through sidedraughts. You could possible use one and let the turbo suck through it.
Mp9 does not do turbo either.
So realistically you can use just the bottom end.
You have to find a way to drop the cr if you want to use that head or put a 16v head on that bottom end.
Budget around R50k+ for a proper turbo conversion.
'09 Audi Q5 3l tdi
JakesVW
Post by JakesVW » Thu Sep 07, 2017 6:05 pm
panic-mechanic wrote:you cannot blow through sidedraughts. You could possible use one and let the turbo suck through it.
Ok perfect!! Thank you very much!
