Mk2 16v kjet
- Car Model: MK5 gti
Mk2 16v kjet
Watsup need help regarding my mk2 16v jet. The warm up regultor fuel line is leaking. Any ideas on how to fix.
'06 MK5 Gti - viezu sw and viper dp
'87 Jetta cli 16v exec
'08 polo 1.6 comfortline
'03 mk4 gti - revo sw and fastcar exhaust
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Re: Mk2 16v kjet
Yup. Take it to a hydraulics shop and get one made up. They will reuse the ends and put new pipe and collars.
Re: Mk2 16v kjet
Sharp. Thanks
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Re: Mk2 16v kjet
update -So ive been to the two hydraulics shops here in ladysmith and no one can do it. They do not have the tools
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Re: Mk2 16v kjet
Why don't you consider going FI?
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
- Car Make: VW & SEAT
Re: Mk2 16v kjet
If your K-Jet is working, just try and get it fixed. K-Jet is great..
- Wolf Mk2 16V
Re: Mk2 16v kjet
Man to my own heart!94CTi wrote:If your K-Jet is working, just try and get it fixed. K-Jet is great..
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
Re: Mk2 16v kjet
It is already FI....kylebassani wrote:Why don't you consider going FI?
Re: Mk2 16v kjet
Take a picture of the pipe you need. Maybe I have one lying around.
And they are just lazy. They can even cut the end off and braze a fitting on that they have the tools for.
Last edited by panic-mechanic on Tue Sep 05, 2017 9:52 am, edited 1 time in total.
Re: Mk2 16v kjet
My bad...meant EFIpanic-mechanic wrote:It is already FI....kylebassani wrote:Why don't you consider going FI?
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Re: Mk2 16v kjet
So spend around R5k or more to fix a leaking pipe. Yup perfectly logical.kylebassani wrote:My bad...meant EFIpanic-mechanic wrote:It is already FI....kylebassani wrote:Why don't you consider going FI?
Re: Mk2 16v kjet
I got prices to convert it to efi R8000. The kjet is working ok but it is going to give me problems later. Can feel it coming. Panic thats the disadvantages of not living in a city i think
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Re: Mk2 16v kjet
Look I'm not trying to argue the best option here, that is why I merely asked why it shouldn't be considered. Whether it is the best option or cheapest that I cannot comment on, I've never done it myself. I have seen that it is unfortunately becoming more and more difficult to maintain the K-Jet system. Again I am not saying it is impossible, but difficult non the less. And if the car is a daily, it makes it worse I suppose because you need to sort out the problem as quick as possible again not sure how quick an EFI mod is. I suppose looking at the cost it doesn't justify it i.e. about R 2500 for management and probably another R 2500 for labour to install if you are not doing it yourself and to get it tuned.panic-mechanic wrote:So spend around R5k or more to fix a leaking pipe. Yup perfectly logical.kylebassani wrote:My bad...meant EFIpanic-mechanic wrote:It is already FI....kylebassani wrote:Why don't you consider going FI?
I am also trying to ask the questions because I am trying to learn as much as possible, if that is not allowed. Please let me know and I will refrain from asking questions.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Re: Mk2 16v kjet
You can literally rent a car, drive to jhb, get a one of pipe made up, drive back to ladysmith for about a third of the price of doing an efi conversion. Those are rarely without any issues and either and you ahve the same problem of being removed form people that are really good at making them work too. Just becuase you now have one broken pipe does not mean it is suddenly going to stop working.
I understand givving advise like that but it is not a sensible option to get around a single broken pipe.
And there are many removed k-jet systems lying around that you can source a pipe from.
I am still waiting for that picture.......
Re: Mk2 16v kjet
Will send this afternoon
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Re: Mk2 16v kjet
Can u pm me your number panic
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Re: Mk2 16v kjet
Apologies for the bad advise.
Maybe a brake and clutch specialist can help, if they make up braided hoses for brake lines I'm sure they might be able to help with the fuel line. They should possibly have the tools to do the work.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Re: Mk2 16v kjet
I have sent a contact number. Plan can be made with the pipe. Just show me which one. If fall else fails send me the thing I'll get it fixed for you.
